came back from three weeks away eager to test drive my 1.8t with newly fitted KW v3's and polybushes all round only to find my car still on the ramp!
Apparently they couldn't get the front camber right. not even close -0.11 left and -1.21 right IIRC, meant to be within 0.5 of each other
Adjustment is normally through slackening the subframe off and sliding side to side whilst car is suspended and I have too much on one side and not enough on the other with no further movement allowed in the subframe.
measuring the lower arm geometry the number right and left don;t match up. 5mm out in one place.
having to replace lower arms to test if that is the problem. if not then it will have to go on a jog to see if the chassis is off somewhere!!
Anyone ever had geometry setting difficulty through damaged/bent suspension parts?
