RapidAssistant
I have seen this particular issue before with B8 platform Audis on other forums but can't seem to get a definitive answer...so trying again.
The car is making a distinctive "knock" or "cracking" sound when you move off, and makes it again as you are slowing down into a junction. It seems to be coming from the front RH side.
What is baffling is that it doesn't do it once you are travelling at speed, or when you are going over bumpy roads which , if logic dictated, would rule out a suspension/steering issue.
I've heard on some forums that it could be an engine mounting which are a known weak spot I'm also hearing things about loose subframe bolts, or something as silly as the exhaust pipe knocking against the underside of the car. I am coming up to MOT time soon, so would like to get a handle on it before then. Anyone had a similar problem?
