Recently I've been logging the MAF (using Torque and OBD Doctor) on my car as I've had a few things done to it and wanted to see if there was any change registered.
The car has been logged as it was the day I collected it and then after a fuel filter change, after a Carbon Clean on the engine, after new coil packs and spark plugs, and after a remap.
The maximum figure I have seen is 183 g/s. The lowest is 178.4 g/s (before all the work mentioned above).
After each item was replaced or the remap installed there has been a noticeable improvement, certainly with the remap, but the MAF readings don't indicate much of a change (if anything they are low even for a standard car).
The car is performing well, so I'm not sure why the readings are so far out. Anybody able to shed some light for me?
