Due to be taking the Mrs to Bath for the day tommorow with an overnight stop for our anniversary and lo and behold the car throws a spanner in the works by throwing a MIL last night. Looks like we will have to take her MX-5. I think it may be a multiplug somewhere. I cleared them and as soon as I started it they re-appeared so it is a hard fault of some type.
Details :
VAG-COM 607 HEX+CAN-USB (Ross-Tech) car is a 2005 UK Audi A3(8P) 2.0TDi DSG.
Codes from scan :-
VAG-COM Version: Release 607.3-UD
Control Module Part Number: 03G 906 016 DT
Component and/or Version: R4 2,0L EDC 0000AG 7000
Software Coding: 0300078
Work Shop Code: WSC 78387
3 Faults Found:
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 000 - -
Freeze Frame:
RPM: 1260 /min
Torque: 16.0 Nm
Speed: 7.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 11000000
Torque: 180.0 Nm
Torque: 0.0 Nm
17075 - Fan 1 Control Circuit: Short to GND
P0691 - 000 - -
Freeze Frame:
RPM: 798 /min
Torque: 30.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11000111
Temperature: 83.7°C
Duty Cycle: 9.6 %
19558 - Motor for Intake Manifold Flap (V157): No Signal
P3102 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 18.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 92.0 Nm
Readiness: 1 1 0 0 0
Thanks,
Paul
Details :
Codes from scan :-
3 Faults Found:
P3101 - 000 - -
Freeze Frame:
RPM: 1260 /min
Torque: 16.0 Nm
Speed: 7.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 11000000
Torque: 180.0 Nm
Torque: 0.0 Nm
P0691 - 000 - -
Freeze Frame:
RPM: 798 /min
Torque: 30.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11000111
Temperature: 83.7°C
Duty Cycle: 9.6 %
P3102 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 18.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 92.0 Nm
Thanks,
Paul
