Hi,
I just fitted a fully reconditioned turbo after mine went (see attached picture, it had a bad day)
However when accelerating and boosting, the turbo is spooling and isn't kicking in until 3500 rpm and is just a bit in and out makes it own mind up. Loss of acceleration power in first and second unless i hold clutch and give it some revs Do i need to position the actuator on the turbo and set it ?
No codes are present.
ESP lights have come on suddenly as well :/ (steering angle sensor came up on vcds)
I have checked the vacuum lines and they seem fine.
On idle it's 830 rpm with boost pressure of MINUS -2.54
MAF was looking fine.
Bottom inter cooler pipe has slight leak (as they do), but dripping oil still so I assume this is the reason for low boost pressure.
Vacuum Pressure on idle is 2 kp.
Turbo made it to 203k miles, engine made it to 190k with new bkd-c fitted.
New egr valve + actuator. However when engine running it's clicking. I have had the clicking noise before on transits when the engine is stopped it clicks and shutters the flaps to move buildup
Thanks,
Nick
Thanks,
Nick
