Facelift Weird Tyre Wear on RS3 (FL)
Daniel Knight
37
Buckinghamshire
I've had my RS3 for 6 months from brand new. It's had a couple of ongoing issues during this time such as the oil consumption and squeaky brakes. After going back and forth with Audi (as they could never replicate the brakes) they finally discovered an issue with 2 of my pads. Whilst replacing these they discovered that my 2 front tyres had worn on the inside of each tyre, one of them was so worn the beading was showing.
So I ask, has anyone else had tyre issues on their RS3, specifically wearing like this...
*Car has done 10,000 miles. It's my family car so a lot of those miles are easy driving.
10,000 miles on the P Zero’s is about the expected lifespan for most people, which I’m sure most will back up... some people are seeing the fronts go after 7000 miles. Mine are on 4.5mm all around at 7500 miles, mixture of driving but the wear is definitely heavier on the inside than the centre to outside of the tread, despite proper wheel alignment.
I’d put it down to wheel alignment out and just the amount of mileage done, change them and get the wheel alignment checked.
What issue did they find with your pads out of curiosity? We all have squealing brakes, mine are probably used heavier than average as I drive locally, stop starting but spirited driving on such roads seems to keep them squeal free... I will still replace them for Ferrodo pads when they go though got good measure.
IIRC I did about 12k miles of reasonably hard driving and they were shot to bits. Worth getting all the alignment checked but doesn't sound a million miles away from what is expected. Even the FL is still a heavy car at the front.
Well, if a dealer has discovered this wear but cannot give an explanation - then that is the final straw! It is basic mechanics for heavens sake!
Inside wear is alignment, camber angle or ball joint wear. To narrow it down further, is the wear pattern sharp on one side and smooth on the other? If so, then alignment.
Reactions: sve170, DW81 and AudiNutta
The tyres have worn on the inside fronts of every 4WD Audi I have owned, torsion and haldex based.
Incorrect toe in is usually the main culprit, not camber, although it is exacerbated with neg camber. Neg camber on it's own is seldom a problem until the toe in is way out.
What is the outside edge and centre depth?
Reactions: Slowracer
I've been through 2 set of fronts and 1 set of rears in 14k miles.
Found that tracking was out from new and after going to Audi twice to have the tracking done they still didnt get it right.
Ended up going to a local European car specialist who have a Hunter 4 wheel alignment machine and its been fine ever since.
Reactions: KKOG, sve170 and Behind The Bins
Same here
I just checked my tyres and the right hand driver side one is down to the wire on the inside shoulder with the rest of the tyre not really worn that much.
The car has only done 8,000 miles since the last tyre change which was done at 9,000 miles.
The first tyre change had the same issue and the dealer said it was probably down to incorrect tyre pressure being applied.
Since then I've made sure it wasn't over or under inflated.
I have noticed a bit of a shudder at 70 mph so just thought the balance was a bit out.
The tyres are under the Audi Service plan so I'm getting my money's worth from that.
So when I go to the dealers I'll ask them to do a 4 wheel alignment so the tyres will last longer than 8k.
Got all 4 tyres replaced with Audi Service plan.
The dealer wanted £120 for 4-wheel tyre alignment.
I was thinking of going to an tyre fitter to ask for a 4-wheel alignment to stop the wear on the outside of the tyre.
Can any tyre fitter do the alignment or do I need to ask for something specific?
Anybody with alignment kit.
But find a place that has Hunter Alignment, it’s the best in the business and what Audi use... it’s commonly used now, can tell by the big hunter sticker in the middle of the laser bar on their alignment ramp.
Reactions: XPOWER
I took the car for a wheel alignment over the weekend.
The front was slightly out but in the green with the rear was out and in the red.
They couldn't do one thing which I think was the camber but I could could have miss-heard what it was.
I will keep an eye on the tyres to see if there is wear on the inside.
It’s usually Caster that cant be adjusted.
No big problem.
As long as everything else is in the green and as close on each side as possible.
Reactions: XPOWER
No big problem.
Mine was all green but still shredded the inside of the tyres, 3.5-4mm tread remaining otherwise.
Any ideas?
:scared2:
Reactions: Terminator x and Callump01
... I’m a little confused where that’s come from, please enlighten
This forum is a nightmare on times
You asked if I had any ideas about your tyre wear
Why would I ?
I don’t drive your car do I ?
I don’t know how you’ve modified your car....
You say your alignment was in the green yet you have inner edge tyre wear on both fronts...
If you for some reason still have an issue you need to seek professional help, all people will do on here is second guess the issue.....
I have at least 19k miles out of my Pirreli RO2 tyres, even more on the rears. No issues on the wear either.
I would get the alignment checked at a professional place. Just because they have a machine doesn't mean they know what they are doing. I suspect the Tow will be the issue IMO.
Camber can be adjusted, by moving the subframe. Castor can at the least be equalised on each side.
That's fair enough @T-800 but I think the "not bothered in the slightest" comment was unnecessary. You probably need to change your signature details "...if Audi won't help...hire T-800" ;)
Reactions: Bells, Terminator x, AudiNutta and 2 others
Why would I ?
Bit unnecessary I think with the original comment mate, he was only asking for a bit of advice which is one of the reasons this forum exists surely. :icon thumright:
Reactions: Bells, oli356, AudiNutta and 1 other person
Yeah I’ll do that.
Better still to get my account deleted.
If he needs advice the he should seek a true alignment / geometry expert.
How can we be expected to diagnose a tyre wear issue ? When he has already had it done.
I agree with James comment above, if the car has been set up correctly there will be no issues.
Yeah I’ll do that.
There's clearly some underlying issue here that's making you grouchy (more than usual ;) ) but for what it's worth, I think you're one of the most knowledgeable and generally helpful guys on this forum.
Reactions: Pinky1959 and Terminator x
Why would I ?
Ok but your comment suggested you have a bit of a problem with me, it wasn’t very nice was it.
I’ve been to the professionals who have said they don’t know what it could be. You seemed to be well in the know, I thought I’d ask but I know better now, thanks anyway.
That’s what the comment told me.
The reason I asked T-800 specifically is because of his apparent knowledge.
Sick of reading about certain people moaning about every little issue with their car.......
It’s not just me either, several other owners have said the same thing....
Gotta understand though bud, this is the internet and we're on a forum for motoring enthusiasts. We all care a lot about our cars or we wouldn't be here talking about them all the time. There's going to be people complaining here and there but it doesn't mean you need to respond to them. Just read the post and move on rather than posting a grouchy response that's no help to anybody imo :blush:
Back on topic though, I had a similar issue @AudiNutta. I have 4mm of tread left on the front insides when I measured yesterday but my outsides are bare, so I've just ordered a set of MPS4S' and will see how they fair. I've had a ****** good offer from Michellin themselves that if they cause any issues with TC (as has been seen from others) then they'll refund me in full! Couldn't say no to that.
Ok ‘Bud’ I’ll do just that....
Yeah I’ll do that.
Don't go T800 some of us still like you :) we just stay away in the AM cos you are grumpiest then ;)
TX.
Reactions: D0C
TX.
Sorry John I’m grumpy in the pm too......
Am off to see if I can find an issue with the car.
Then I can post freely.
Reactions: A_Davison, D0C and Terminator x
Ah this forum really ain’t worth the hassle, pi**es me off every time I come on here.
That’s the end of it, back to enjoying my holiday and updating my never ending list of issues.
.... into the shadowsssssss :salute:
Reactions: Jonny B, sve170 and Callump01
Imho the two of you are both "characters" on ASN and the place is better with you here #grouphug
TX.
Reactions: Pinky1959 and AudiNutta
TX.
Aye who else would bring a wave of negativity if it wasn’t for me? :haha:
Reactions: Jonny B and Terminator x
All four Pirellis are now off and Michellin PS4S are on.
Some pictures below showing the weird tread wear on just one of the tyres. Had the alignment checked and it was all green too, tyre pressures also checked and kept within the sticker spec every couple of weeks.
Will not be going back to the Pirelli's unless they can sort out the uneven wear issues that lots of other owners are facing.
Wow, they are proper f*****! What is going on indeed? The PS4S are a cracking tyre though :icon thumright:
Reactions: Callump01
Yep, terrible isn't it?
Agree with these PS4S' though - the level of grip is absolutely phenomenal in comparison to how my Pirellis were; especially happy with the wet weather performance! We should have had these fitted to our cars from the factory.
Reactions: sve170 and AudiNutta
How much are you guys paying for the Michelin’s ?
