A4 esp / abs light help
Alex dark
Got abs and esp lights on in my A4 b7 8e . Scanned car and changed sensor , now light is on almost straight away when driving . Car failed mot over this and need to get it sorted ! Please help
Friday,03,August,2018,18:41:33:42103
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
www.Ross-Tech.com
VIN: WAUZZZ8E45A463260 License Plate: FE55ZPS
Mileage: 246860km-153391mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E45A463260 Mileage: 246860km-153391miles
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00502 210 91521
VCID: 75E466B11C6541EC07-8020
6 Faults Found:
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 000 - Short to Plus
Freeze Frame:
RPM: 1722 /min
Torque: 90.0 Nm
Speed: 86.0 km/h
Load: 26.3 %
Voltage: 14.14 V
Bin. Bits: 00101000
Torque: 244.0 Nm
Torque: 109.8 Nm
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
16955 - Brake Switch (F)
P0571 - 000 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 882 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101001
Torque: 158.6 Nm
Bin. Bits: 0 01 0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
VCID: 264671FD91437A747E-8072
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x00FF
Hex Value: 0xFF94
Hex Value: 0x00FF
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x1004
Hex Value: 0x4212
Hex Value: 0x00FF
Hex Value: 0xFFAF
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6BD040C91921871CE1-5120
3 Faults Found:
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
30-00 - Open or Short to Plus
09-00 - Adaptation Limit Surpassed
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 K
Component: int. Lastmodul ECE 0304
Coding: 10001
Shop #: WSC 06325
VCID: 3A7EB58D26FBEE942A-4AE6
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M001N9J/
Coding: 0033622
VCID: 3B70B0897AC1D79C31-806E
Subsystem 1 - Serial number: 6332DRB40120CC0AK
Subsystem 2 - Serial number: 6342DRB4012091A3A
Subsystem 3 - Serial number: 6352ARB4003FF680T
Subsystem 4 - Serial number: 6362ARB4003FF6AE3
Subsystem 5 - Serial number: 63729RB4003FD5A5Y
Subsystem 6 - Serial number: 63829RB4003F9ABD2
5 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 229
Reset counter: 99
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 37
Reset counter: 99
Time Indication: 0
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 99
Time Indication: 0
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 66
Reset counter: 99
Time Indication: 0
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 05042
Shop #: WSC 00000
VCID: 418CC2614B2DBD4C6B-4B00
1 Fault Found:
01301 - Control Module for Voice Recognition (J507)
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 950 S HW: 8E0 920 950 S
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006441
Shop #: WSC 00046 412 81920
VCID: 397CAA8173FDE58C23-5120
3 Faults Found:
01314 - Engine Control Module
01321 - Control Module for Airbags (J234)
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006441
VCID: 397CAA8173FDE58C23-513C
3 Faults Found:
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 08187
Shop #: WSC 06325
VCID: 7DF47E91775519AC4F-4B00
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
3 Faults Found:
01134 - Alarm Horn (H12)
00962 - Alarm via. Tilt Sensor
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 M
Component: symphony II PM6 0410
Coding: 01205
Shop #: WSC 00256
VCID: 316C92A1FB8D2DCC9B-5072
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
36-10 - Open Circuit - Intermittent
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 B HW: 8E0 919 283 B
Component: Parkhilfe 4-Kan H06 0020
Revision: 00H06000 Serial number: 00067802030435
Coding: 0000114
Shop #: WSC 131071 1023 2097151
VCID: 2F6894D9BDB93B3C8D-513C
2 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground - Intermittent
01543 - Parking Aid Warning Chime (H15)
End-------------------------(Elapsed Time: 06:34)--------------------------
Well glowplugs would either be all are toasted or loom is faulty.
Google engine mount solenoid A4, common discussion as is brake switch, that probably needs replacing in footwell.
Thanks , ordered one from TPS today. Will update thread when fitted and tested
Wheel speed sensor faults throws up the ABS fault light, the ecu knows the signal is implausible meaning ESP and ABS won’t work.
2 speed sensors have been faulty in my A3 for years, If I clear the codes with VCDS the light stays off long enough for the MOT
Brake light switch changed, seems to be working and checked operation in VCDS.
ESP light is permanently on, ABS light is illuminated when 5mph is exceeded.
Borrowing a laptop with an actual usable battery to check operation of ABS sensors.
Log is included below:
Tuesday,07,August,2018,06:44:27:42103
www.Ross-Tech.com
Mileage: Repair Order: 4
67 69 75 76 77
Coding: 0000072
5 Faults Found:
Freeze Frame:
RPM: 0 /min
Torque: 90.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 351.4 Nm
Freeze Frame:
RPM: 840 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00101100
Temperature: 14.4°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 840 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00101100
Temperature: 14.4°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 840 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00101100
Temperature: 14.4°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 840 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00101100
Temperature: 14.4°C
Bin. Bits: 10110000
Readiness: 0 0 1 1 1
Coding: 0004401
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x00FF
Hex Value: 0xFF8C
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x1104
Hex Value: 0x4212
Hex Value: 0x00FF
Hex Value: 0xFFB0
Hex Value: 0x00FF
Coding: 00000
Shop #: WSC 00000
VCID: 6BD040C91921871CE1-513C
3 Faults Found:
Coding: 10001
Shop #: WSC 06325
VCID: 3A7EB58D26FBEE942A-4B00
Coding: 0033622
Coding: 05042
Shop #: WSC 00000
1 Fault Found:
Coding: 0006441
Subsystem 1 - Part No: 8E0 920 950 S
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 0006441
Coding: 08187
Shop #: WSC 06325
1 Fault Found:
Coding: 01205
Shop #: WSC 00256
VCID: 316C92A1FB8D2DCC9B-5054
Coding: 0000114
VCID: 2F6894D9BDB93B3C8D-5120
2 Faults Found:
End-------------------------(Elapsed Time: 06:46)--------------------------
What a coincidence my ESP light came on today and wont go away too, happened when I was braking, and the rear brake lights bulb faliure warning has been coming on and off recently too. Seen many people write brake light sensor so all the evidence is pointing towards this.. is that assumption correct? :blink:
I changed my brake light sensor and checked it’s operation on vagcom and still no joy.
Rear right abs sensor registers no speed at all.
I disconnected battery for about half hour, connected back up, let it run for abit and esp warning light has gone, took it for a decent drive hard braking/acceleration and all seems fine. I have no doubt it will make an appearance at some point though lol
I’m not sure at this point. You might have problems with your abs sensors.
I wish mine would do this ! Ha
Next job is to
Change rear wheel bearing and see if that affects anything , then another genuine sensor.
Any other ideas ? :)
Next job is to
No idea man. Like I said in my post itll make a return.. it has.. so i will be following this posts lol, ill update you what I do and see what happens.
I have one possible theory - On my B6 Audi, I had a problem with the ABS warning light - VCDS told me it was the rear D/S sensor so I changed it (what a SWINE of a job when its seized solidly in place) but that didn't cure it! Not a happy bunny.
Took it off again & with a bright torch, looked in the hole in the hub carrier whilst rotating the hub slowly. Bingo! found that the ABS ring on the driveshaft had rusted through & broken which put a gap into it that the sensor picked up as a fault. So, after some dismantling and swearing (lots of swearing) I managed to extract the drive shaft out of the hub, remove the broken ring from it, clean it up & fit a new one (it's the same as the front driveshaft one.) That finally cured the fault. Maybe it's what's wrong with yours too?
End of driveshaft with old broken ring & new replacement
Compilation 1 150dpi
Compilation 2
Reactions: Screaminkiwi
Is it just me? Seems that when I post into a thread that I'm following just lately......... it appears to kill it stone dead! :grumpy:
Maybe the level of mechanical knowledge needed for your reply baffles some people mate.. :pride: but good on you for doing it yourself, since I posted here the ESP light has gone and hasnt returned since.. so im thinking my issue is a sensor somewhere!
P
771
Pedrödelabongo
P
NHN
