Ceramic brake pads
S3-StevePn
Salisbury, Wiltshire
I've had my S3 a couple of weeks now and can't believe how dirty the wheels get.
Has anyone changed their pads over to ceramic and if so do they produce less dust?
I can only fine ATE and EBC Red Stuff.....
Plus the rotors are in good condition but is it worth replacing them at the same time?
TIA, Steve
I put EBC Redstuff on the S7 for two reasons:
1. Low speed braking squeal from the OEM pads was horrendous. After 4000miles I changed to the Redstuff's.
2. Brake dust is now non existent with the Redstuff's fitted.
Im on my original discs - now at 32k Miles, - and wear is hardly noticeable, so no need to change unless your looking to upgrade to something different.
:racer:
Reactions: 45bvtc, DeeGee68 and S3-StevePn
:racer:
Thanks for this.
Do you rotors have surface rust on and is it worth painting them?
I fitted redstuff pads on my S3 400 miles ago and as said above brake dust is significantly lower. Even after a good spirited drive on some back roads where the brakes get a good hiding the wheels are still clean.
Reactions: DeeGee68 and S3-StevePn
Well I’ve just order a set for both front and rear.
The local specialist will charge no extra if I change the rotors at the same time.
Plus it saves some time and money having to paint them.
Reactions: DeeGee68
4 years later and no rust or paint peel says yes .
No experience of the BBQ flavour .
Reactions: Jassyo06
Thanks for this.
I painted mine with POR15 silver. Did same on my old RS3 and had no rust come through
Reactions: 45bvtc
I didn't realise discs can be painted ..... Surprised the pads don't rub the paint off.
Sent from my HTC 10 using Tapatalk
Reactions: Scotty75 and S3-StevePn
13
7K
39
8K
21
26
6K
