JJ_2018
Ok so I’m opening myself up here to a lot of criticism so play nice!
I picked up my brand new A3 saloon and drove it home, I’d had the car for about an hour and when I got home started to reverse park it on my narrow drive.
I took the usual tight angle and made sure not to scrape the side and then decided to straitened up for the big reverse.
This is where the drama unfolds....I drove the car forward close to the stone wall in front, selected reverse but to my horror when I released the clutch and applied the accelerator the car moved forward! I instantly pressed the brakes and assumed I had selected 1st instead. So I checked the gear and when for another go...same thing!!!
The car is now millimetres away from the stone wall and I mean literally you could maybe get a finger in there at a push (that’s what she said).
Having cold sweats at this point and decided to run around to all the local houses for help, as it’s a Monday afternoon no one is in and after about 10 min I find two people one old man in his 70s and another builder type. After the initial shock they managed to catc the car when I released the brake and push it a meter back (very very lucky to catch it before it even rolled a bit).
I then managed to drive my out to check I can select reverse properly. I have no idea what went wrong and now feel like a little damsel in distress as I pride myself on my ability to manoeuvre :/
Ok...take your shots
On a serious note - what actually went wrong as I was positive I was in reverse in both occasions.
