HELP! OBD FAULT CODE!
J88MXL
London
A little back story, I got a 54 plate A3 3.2 V6 which had a Straight Pipe exhaust just recently and when I bought it and drove it home there was no error codes/fault codes. I recently then drove the car again for a much longer period of time and on the way home some the check Engine light came on. There was only 1 error code but now there seems to be 4. Is this because of the straight pipe? I’m not too sure if it’s had a d cat also? I’ve taken pictures of the code (sorry it’s a rubbish obd). Any help would be appreciated!
Best to put this post in the correct section Vcd's
Not a NOOB thing to say , best to look through the site then you will grasp the concept off how the site works , thats all the advice i have
Reactions: J88MXL
Hi @J88MXL - I have the 3.2 as well. It was de-catted. When I first drove the car there were no EC lights but after a couple of starting cycles the EC light came on. I’d clear the code and it would stay off for several more start/stop cycles.
I can’t remember the codes specifically but it was to do with flow. I fitted some spacers between the lambda sensors and they sorted the flow errors but I then had bank 1 and bank 2 rich errors. So, I refitted the cats (came with the car) and now no errors at all.
Check if your cats are in/out but that’s possibly the cause - your errors are on both banks.
Reactions: J88MXL
Thanks mate! Gonna take it to the garage as soon as and get it lifted to properly check. Might need to refit them or get a o2 sensor delete. Thanks for the insight
