Acc & Breaking guard unavailable
audinorway
Norway
Hi
I have a problem with my RS6. I got an error saying ACC & Breaking Guard not available.
Here is copy from scan. Can someone please help me out here.
Friday,31,August,2018,17:27:04:13974
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 18.2.1.2
Data version: 20180518 DS287.1
www.Ross-Tech.com
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 1B 20 22 28 36 3B
3C 42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 85 88 89 8B 8E
8F 90 BA
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: Malfunction 0010
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
BA-Motor Mounts -- Status: OK 0000
Address 01: Engine (------CRDB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 560 HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0012
Revision: NCH62---
Coding: 122A003265460B0A1000
Shop #: WSC 30477 001 1048576
ASAM Dataset: EV_ECM40TFS0114G0906560 001013
ROD: EV_ECM40TFS0114G0906560.rod
VCID: 65C18D286457506CB4-8030
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 BD HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H16 1001
Revision: --H16---
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 71E9E978A09F8CCCD8-8024
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 P HW: 4G0 907 379 P
Component: ESP PREMIUM H09 0100
Revision: -------- Serial number: --------------
Coding: 64BF990126FD9980CB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004036
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3E730244A14123B415-806A
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FP HW: 4H0 907 064 DP
Component: BCM2 2.0 H35 0560
Revision: 00002001
Coding: 05A92F06000000000000
Shop #: WSC 29611 001 1048576
VCID: 7CF7C84CFFDDF1A47B-8028
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4G8 959 760 C HW: 4G8 959 760 C
Component: MEM-BFS H04 0154
Revision: AA000000 Serial number: 00000068403756
Coding: C018320085006201010001010101112030303333283333
VCID: 3A7B0E54B5690F9429-806E
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AF HW: 4G0 820 043 AF
Component: KLIMA 4 ZONEN H13 0087
Serial number: 17071300040848
Coding: 688200BE05
ASAM Dataset: EV_AirCondiComfoUDS 002040
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 63C593306A632E5C5A-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001758334
Coding: 0907201009749FF2B98100C4A0001800CF9CC7082E08020180 0108546F01
VCID: 6FEDEF00BEAB9A3CCE-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 130628 H36 0080
Serial number: 130717215131
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21579041
Coding: 0200FD
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Serial number: 24 07 2013 00000052
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000012071300010871
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000012071300010714
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA107413000004178965
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 5ED84CB6000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AC HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0091
Revision: 11001001 Serial number: 61031319600003
Coding: A8EB1B
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 73E5E370DA83BEDC2A-8026
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000
Coding: 7E04010102
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 285FC41C53C58D044F-807C
1 Fault Found:
145152 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 52
Mileage: 95622 km
Date: 2018.05.18
Time: 20:38:18
Control Module temperature: 28 °C
Voltage terminal 15: 14.599 V
Velocity_vehicle_reference: 9.52 m/s
Longitudinal_acceleration_vehicle_reference: 0.73 m/s²
Address 14: Susp. Elect. Labels: None
Part No SW: 4G0 907 376 HW: 4G0 907 376 A
Component: J250 DRC FahrwerH01 0040
Revision: 00000000 Serial number: 00894015077400
Coding: 0000000
VCID: 6BD5FB104AB3661CE2-803E
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00EDNUW
Coding: 30323436313330303335554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 36631A648971EBF4CD-8062
Crash sensor for side airbag: driver side:
Serial number: 3575HRB401250J0K91CJ
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB401250J0K694H
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB401650KJOJ142
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB401C50KRAFH1C
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400U50M2EPH2Z
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400U50M2ENH9+
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372MGO000M5
Coding: 0004FD
VCID: 387F145C8B651D84DF-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0010
Serial number: 03 07 2013 D0260094
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G0 920 931 B HW: 4G0 920 931 B
Component: TBenRdwAccNv H80 0618
Revision: 30460230 Serial number: 658240713596004
Coding: 138F110BAFD50008000400
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 2541CD2824D7906C74-8070
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000001040954
Coding: 00E5074800
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001_AU57.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 5257710903
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 130605000000000002C5
1 Fault Found:
0267 - Optical data bus
U1049 00 [008] - Open circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 96280 km
Date: 2018.08.16
Time: 12:15:15
Voltage terminal 30: 11.8 V
Voltage terminal 15: 0.0 V
Control Module temperature: 30 °C
System status: Awake_Timer_active
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 L HW: 8K0 907 144 L
Component: DYNAMIKLENK. H06 0720
Revision: 52001005 Serial number: --------------
Coding: 010100
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 040182646E6E645A5A253D3E00
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0200
Serial number: 001607130001788
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
ROD: EV_AllWheelDiffeQSPFR.rod
Address 28: HVAC, Rear (E265) Labels:| 4G0-919-158.clb
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0087
Serial number: 25071300040223
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
ROD: EV_ClimaContrUnitRearUDS_002.rod
VCID: 377D17608E7B12FCD6-8062
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H04 0154
Revision: AA000000 Serial number: 00000068403800
Coding: C0183B0085016201010001010101112030303333203333
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H02 0056
Revision: -------- Serial number: EJ1BPA7E00L8ST
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 K HW: 4G0 907 566
Component: J769 SWA MasterH04 0010
Revision: 00H04000 Serial number: 6PZ 010 287-09
Coding: 0000105
VCID: 377D1760467B12FCD6-8062
Subsystem 1 - Part No: 4G0 907 568 K
Component: J770 SWA Slave H04 0020
Subsystem 2 - Serial number: 6PZ 010 287-29
Subsystem 3 - Serial number: 5F24.07.1300H04000AMS14115ÿ
Subsystem 4 - Serial number: S14115ÿ
2 Faults Found:
02856 - Sensing Area for Control Module 2 Blocked
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 95622 km
Time Indication: 0
Date: 2018.05.18
Time: 20:38:17
02850 - Control Module 2 for Lane Change Assistance (J770)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 52
Mileage: 96299 km
Time Indication: 0
Date: 2018.08.17
Time: 19:14:09
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F16015E00628202080013
VCID: 45816DA8CC97706C54-8010
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H38 0010
Revision: 00001000 Serial number: 0030721624
Coding: 011001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326B26746519F7D4E1-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0311945686
Coding: 013A0E20A0B93081833009840C031247000000000000000000 0000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00004072828
Coding: 010000
Subsystem 4 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B
Component: GEB.F.Heckoef H16 0810
Serial number: 93002366
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000195318
Coding: 030000
VCID: 1D31E5C8048758AC2C-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
Coding: 011F16015E00628202080002
VCID: 46836AA4F1917B745D-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000778038
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C57380C473DA124AB-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130729-0002-015
Coding: 1122A6601002B300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2D5135087C27A82CBC-8078
1 Fault Found:
764928 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 94464 km
Date: 2018.03.08
Time: 16:45:57
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227G$0D7836116
Coding: 010003010000000001
VCID: 2643CA2451D19B747D-8072
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 Q HW: 4G0 035 670 H
Component: H-BNT-EU H51 1034
Revision: -------- Serial number: 190G+0D7546733
Coding: 070100010303E9EF7DB0CB1E00000003080001000000000000
VCID: 31692978681FCCCC98-8064
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD001RRB8
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349MGM000FI
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5298
1 Fault Found:
02067 - Optical Databus; Unpermitted Wake-Up Request
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 96280 km
Time Indication: 0
Date: 2018.08.16
Time: 12:12:13
Freeze Frame:
Voltage: 11.80 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0507
Coding: 010F14004000628202080002
VCID: 49996198E08F940CB0-801C
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 HW: 4H0 907 273
Component: RDKBERU25 H09 0700
Serial number: 10000000003796
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 68DF841C93454D048F-803C
1 Fault Found:
12652551 - Tire Pressure Monitoring
C10DC 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 64
Mileage: 94879 km
Date: 2018.03.28
Time: 14:25:15
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0150
Revision: 11001001 Serial number: 82330JF0098840
Coding: 0203000101010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
ROD: EV_CamerSysteTopViewAUDI_005.rod
VCID: 2B553B104233A61CA2-807E
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2643CA2459D19B747D-8072
1 Fault Found:
0001 - Front Heater for Lane-Holding Assist
C1101 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 90
Mileage: 94658 km
Date: 2018.03.14
Time: 13:14:56
Outside air temperature: -47.0 °C
Voltage terminal 15: 13.9 V
Control Module temperature: 36.0 °C
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E04010102
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 52
Mileage: 95622 km
Date: 2018.05.18
Time: 20:38:18
Control Module temperature: 27 °C
Voltage terminal 15: 14.578 V
Velocity_vehicle_reference: 9.19 m/s
Longitudinal_acceleration_vehicle_reference: 0.69 m/s²
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000121707137
Coding: 04C0BB1B1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
1 Fault Found:
0063 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 52
Mileage: 95622 km
Date: 2018.05.18
Time: 20:38:19
Outside air temperature: 18.5 °C
Voltage terminal 15: 14.6 V
Have you tried resetting the errors?
I’d save the scan results first to a local file, then reset the faults.
It’s very common for a single fault to cause a cascade of additional faults, especially in the driver assistance modules.
Some of the faults on your list are quite old, (they are date time stamped) so doing a full clear of the codes will help narrow down what is relative if the fault reappears.
If it reappears, rescan, save the scan results and start looking at the error codes and time stamps to identify what the first failure was.
Thanks for help:)
I reset them all 31 august and the acc & break guard unavailable / lane asssist failure in display came back immediately.
I did not rescan after
Interesting.....
Are you 100% certain you cleared all the fault codes on the 31st Aug?
Reason l ask is the date stamp on most of them is prior to 31st Aug. This is the date the fault was last recorded.
Can you remember roughly when the fault first occurred?
The guy that helped me out with VCDS on august 31 said that he cleared all. And as we started the car the warning lamp / ACC & Break guard unavailable just came up after few seconds. We did not do a new scan after clearing(maybe I should to see what we have left)
This warning lamp / ACC & Break guard and lane assist thing first ever came up in the evening on august 17. Just after the car had been on a shop for chromedelete.
This fault seem to appear the day before (august 16) we got the display warning. Do you think this has anything to do with it?
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 96280 km
Date: 2018.08.16
Time: 12:15:15
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
AND then this fault came up on august 17, same day as the warning in display.
Coding: 0000105
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 52
Mileage: 96299 km
Time Indication: 0
Date: 2018.08.17
Time: 19:14:09
Ok, so optical bus would definitely lead to the symptoms you are seeing. There are quite a few components interconnected using fibre optic cable. This is the optical data bus.
It works in series, so the cable goes from component to component. If any of the components in the path fail, then everything further down stream can stop working, like the front camera behind the mirror, which is used in ACC and other systems. The path fail could be a loose, disconnected or kinked optical cable, or even a component fuse.
It’s only occurred once (Fault Frequency) but, that date and time 16 Aug etc, should have been cleared when the fault codes were cleared using VCDS, so I’m still sure the faults were not been cleared on 31st Aug.
A fault occurring just the once can lead to disabling of the systems you’ve listed as they are safety critical driver assistance programs. A fault on those can cause an accident if your reliant on them, so takes just one problem and the system disables them, and they can only be cleared using using something like VCDS. If you reset the fault codes (again) and the fault reoccurs, the date time stamp would be after the date time the codes were cleared. If the actual fault only occurred the once, then the clear should fix the problem.
Your chrome delete is just a coincidence, as that’s external to the car.
I always run VCDS twice. Once to ID faults, then once after clearing faults to make sure I caught them all....
I would suggest Scan - Clear the codes - Scan again.
Yes, the below link would be a good place to go, if the scan-clear-scan does not resolve the problem.
The “Clear All DTCs” shown on one of the screens is what should be used to clear any stored fault codes.
I’m not an expert in VCDS, just a regular user. Perhaps someone more experienced can jump in with some suggestions....
Good luck!
This is results from scan yesterday.
Code:
Tuesday,04,September,2018,20:53:09:13974
www.Ross-Tech.com
VIN: WUAZZZ4G4EN900924  License Plate: MAGNUS2
Mileage: 96408km-59905mi  Repair Order:
  8F 90 BA
VIN: WUAZZZ4G4EN900924  Mileage: 96408km-59905miles
19-CAN Gateway -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
  Revision: NCH62---
  Revision: --H16---
  Coding: 000001
  Revision: 00002001
  Coding: 688200BE05
  Coding: 0907201009749FF2B98100C4A0001800CF9CC7082E080201800108546F01
  Coding: 0045F7
  Coding: 0200FD
  Coding: 110000
  Coding: 110000
  Coding: 020300
  Coding: A8EB1B
  Coding: 7E04010102
1 Fault Found:
  U1113 00 [009] - -
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 55
  Mileage: 96325 km
  Date: 2018.08.31
  Time: 17:27:35
  Control Module temperature: 60 °C
  Voltage terminal 15: 14.497 V
  Velocity_vehicle_reference: -0.01 m/s
  Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
  Coding: 0000000
  Coding: 0004FD
  ROD: EV_RBD4K.rod
  Coding: 00E5074800
  Voltage stabilizer:
  Coding: 010100
  Revision: AA001002
  Coding: 20
  ROD: EV_SARA2.rod
  Coding: 0000105
3 Faults Found:
  014 - Defective
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 1
  Reset counter: 55
  Mileage: 96325 km
  Time Indication: 0
  Date: 2018.08.31
  Time: 17:27:34
02071 - Local Databus
  014 - Defective - Intermittent
  Freeze Frame:
  Fault Status: 00101110
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 95
  Mileage: 96336 km
  Time Indication: 0
  Date: 2018.08.31
  Time: 18:04:48
  004 - No Signal/Communication - Intermittent
  Freeze Frame:
  Fault Status: 00100100
  Fault Priority: 3
  Fault Frequency: 3
  Reset counter: 95
  Mileage: 96336 km
  Time Indication: 0
  Date: 2018.08.31
  Time: 18:05:18
  Coding: 013A0E20A0B93081833009840C0312470000000000000000000000000000
  Coding: 010000
  Coding: 030000
1 Fault Found:
  C1080 00 [009] -  -
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 55
  Mileage: 96325 km
  Date: 2018.08.31
  Time: 17:27:35
Address 6D: Trunk Elect. (----)  Labels:* Redir Fail!
  Part No SW: 4G9 959 107 B  HW: 4G9 959 107 A
  Component: HDSG-Modul  H03 0143
  Revision: 14003001  Serial number: 193300124
  Coding: 097205C010
  ASAM Dataset: EV_HDSGAu572 001022
  ROD: EV_HDSGAu571.rod
  VCID: 35611D689477E0ECC4-8060
Address 72: Door, Rear Right (J389)  Labels: None
  Component: TSG HR  H03 0507
  Coding: 6A060000
1 Fault Found:
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 3
  Reset counter: 96
  Mileage: 96337 km
  Date: 2018.08.31
  Time: 18:10:19
  Outside air temperature: -38.0 °C
  Voltage terminal 15: 14.2 V
  Control Module temperature: 40.0 °C
Address 88: Multicont. Seat Driver (J873)  Labels:* None
  Part No SW: 4G8 881 073  HW: 4G8 881 073
  Component: P2G  H02 0032
  Serial number: 0D6I5VQ
  Coding: 766FF0
  ASAM Dataset: EV_P2GDriveSideFrnt 001006
  ROD: EV_P2GDriveSideFrnt.rod
  VCID: 6ED3F204B1A19334C5-803A
  Valve Block 1 In Driver Side Front Seat:
  Subsystem 1 - Part No SW: 4G8 907 181  HW: 4G8 907 181
  Component: PSLB  H02 0023
  Serial number: 00000000000000000000
  Valve Block 2 In Driver Side Front Seat:
  Subsystem 2 - Part No SW: 4G8 907 182  HW: 4G8 907 182
  Component: PSML  H02 0023
  Valve Block 3 In Driver Side Front Seat:
  Subsystem 3 - Part No SW: 4G8 907 182  HW: 4G8 907 182
  Component: PSMR  H02 0023
Address 89: Multicont. Seat Pass. (J872)  Labels:* None
  Serial number: 0D6K0EW
  Coding: 366FF0
  ASAM Dataset: EV_P2GPasseSideFrnt 001006
  ROD: EV_P2GPasseSideFrnt.rod
  Valve Block 1 In Passenger Side Front Seat:
  Valve Block 2 In Passenger Side Front Seat:
  Valve Block 3 In Passenger Side Front Seat:
  Coding: 7E04010102
1 Fault Found:
  U1113 00 [009] - -
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 55
  Mileage: 96325 km
  Date: 2018.08.31
  Time: 17:27:35
  Control Module temperature: 54 °C
  Voltage terminal 15: 14.547 V
  Velocity_vehicle_reference: -0.00 m/s
  ROD: EV_BC7.rod
1 Fault Found:
  U1113 00 [009] - -
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 55
  Mileage: 96325 km
  Date: 2018.08.31
  Time: 17:27:35
  Outside air temperature: 24.0 °C
  Voltage terminal 15: 14.7 V
Address 8F: Pretens. Frt Left (J854)  Labels:. 4H0-980-94x-RGS.clb
  Part No SW: 4H0 980 945 B  HW: 4H0 980 945 C
  Component: RGS-VL  H13 0080
  Coding: 0066E608031F0376070308014240C0010000
  ASAM Dataset: EV_RGS_L 002004
  ROD: EV_RGS_L.rod
  VCID: 31692978601FCCCC98-8064
Address 90: Pretens. Frt Right (J855)  Labels:. 4H0-980-94x-RGS.clb
  Part No SW: 4H0 980 946 B  HW: 4H0 980 946 C
  Component: RGS-VR  H13 0080
  ASAM Dataset: EV_RGS_R 002004
  ROD: EV_RGS_R.rod
Address BA: Motor Mounts (J931)  Labels: 4H0-907-145.clb
  Part No SW: 4H0 907 145  HW: 4H0 907 145
  Component: AEM - LEAR  H07 0006
  Revision: 00001001  Serial number: 97809002304700
  ASAM Dataset: EV_AEMLearAU64X 002014
  ROD: EV_AEMLearAU64X.rod
  VCID: 66C38A2499515B74BD-8032
End-------------------------(Elapsed Time: 08:23)--------------------------
When we tried to do a Optical bus diagnosis this message came up
Last scan with hex-net. Scan - Clear - scan before driving. Some of the faults did not show up on this one compared to the one I posted yesterday.
I am complete new to this but what I find interesting is that the control module 2 for lane change fails at 20:17:08. A few seconds later all the other fails come up.
Code:
Wednesday,05,September,2018,20:21:05:25183
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
www.Ross-Tech.com
  8F 90 BA
VIN: WUAZZZ4G4EN900924  Mileage: 96590km-60018miles
85-On Board Cam. -- Status: OK 0000
  Revision: NCH62---
  VCID: E582E9C4E403196C34-80B0
Readiness: 1110 1101
  Revision: --H16---
  Coding: 000001
  VCID: F1AA8D9420CBC5CC58-80A4
  VCID: BE3066A821156AB495-80EA
  Revision: 00002001
  VCID: FCB4ACA07F89B8A4FB-80A8
  VCID: BA386AB8353D4694A9-80EE
  Coding: 688200BE05
  VCID: E386F7DCEA37675CDA-80B6
  VCID: EFAE8BEC3EFFD33C4E-80BA
  Coding: 0045F7
  Coding: 0200FD
  Coding: 110000
  Coding: 110000
  Coding: 020300
  Coding: A8EB1B
  VCID: F3A6879C5AD7F7DCAA-80A6
  Coding: 7E04010102
  VCID: A81CA0F0D391C404CF-80FC
1 Fault Found:
  U1113 00 [009] - -
  [FAULT_CIS_SWA_FAIL]
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 61
  Mileage: 96590 km
  Date: 2018.09.05
  Time: 20:17:10
  Control Module temperature: 41 °C
  Voltage terminal 15: 14.090 V
  Coding: 0000000
  VCID: EB969FFCCAE72F1C62-80BE
  VCID: B6207E880925A2F44D-80E2
  Coding: 0004FD
  VCID: B83C70B00B3154845F-80EC
  ROD: EV_RBD4K.rod
  VCID: A502A9C4A483D96CF4-80F0
  Coding: 00E5074800
  Voltage stabilizer:
  Coding: 010100
  Revision: AA001002
  Coding: 20
  VCID: B73E738C0E2F5BFC56-80E2
  ROD: EV_SARA2.rod
  Coding: 0000105
  VCID: B73E738CC62F5BFC56-80E2
1 Fault Found:
  014 - Defective
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 1
  Reset counter: 61
  Mileage: 96590 km
  Time Indication: 0
  Date: 2018.09.05
  Time: 20:17:07
  VCID: C5C209444CC3396CD4-8090
  VCID: B2284298E54DBED461-80E6
  Coding: 010000
  Coding: 030000
  VCID: 9D72812484D311ACAC-80C8
  VCID: C6C00E4871C53274DD-8092
  VCID: AC145CE0C769E8242B-80F8
  VCID: AD1251E4FC73E12C3C-80F8
1 Fault Found:
  C1080 00 [009] -  -
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 61
  Mileage: 96590 km
  Date: 2018.09.05
  Time: 20:17:10
  VCID: A600AEC8D185D274FD-80F2
  VCID: B12A4D94E84B85CC18-80E4
  VCID: C9DA057460DBDD0C30-809C
  VCID: E89CE0F0131104040F-80BC
  VCID: AB165FFCC267EF1C22-80FE
  Coding: 097205C010
  VCID: B52279841423A9EC44-80E0
  Coding: 6A060000
  VCID: A600AEC8D985D274FD-80F2
  Coding: 766FF0
  VCID: EE9096E831F5DA3445-80BA
  Coding: 366FF0
  Coding: 7E04010102
1 Fault Found:
  U1113 00 [009] - -
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 61
  Mileage: 96590 km
  Date: 2018.09.05
  Time: 20:17:10
  Control Module temperature: 40 °C
  Voltage terminal 15: 14.200 V
  ROD: EV_BC7.rod
1 Fault Found:
  U1113 00 [009] - -
  [SWA_Signal_error]
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 61
  Mileage: 96590 km
  Date: 2018.09.05
  Time: 20:17:10
  Outside air temperature: 19.5 °C
  Voltage terminal 15: 14.3 V
  Control Module temperature: 42.0 °C
  ROD: EV_RGS_L.rod
  VCID: B12A4D94E04B85CC18-80E4
  ROD: EV_RGS_R.rod
  VCID: E680EEC8190512743D-80B2
End----------(Elapsed Time: 03:14, VBatt start/end: 14.3V/14.2V)-----------
Took it to the local Audi dealer today and they had it for one hour. They say the slave control modul is gone. New module and calibration is needed. Hopefully this will solve the problem. ill let you know. Thanks for help!
  1. 02850 - Control Module 2 for Lane Change Assistance (J770)
Reactions: RAF_S7
Problem solved after replacing slave module J770 and calibration. Thanks for all help!
It was £2000 including 60.000km service.
