Hey guys, I was looking at ordering some pieces from Kufatec but it recommends me needing a comfort control unit, how do I know if I need it or maybe I have it already?
If you don't have the power tailgate option from factory then you will need a new Central Convenience module. Keyless retrofit can be done without changing the CCM if you have the power tailgate already.
For Keyless, you also need VAG CAN Pro as VCDS cannot enable it. The unit has to be parameterized instead - it may be that Kufatec can pre-parameterize the module for you. For power tailgate only I'm not sure on VCDS as mine has it from the factory.
Depends how much extra the coding dongle is - might be worth giving @DJAlix a shout as he might be cheaper than buying the dongle.
It might be worth giving him a buzz anyway as the CCM will need component protection removing unless it is a virgin unit from Audi parts. Dealers will do this but a) not many like doing it (to the point where some say it can't be done!) and b) It'll cost you an hours labour! Very few indies have connection to the GeKO server to do this though - @DJAlix does however
