- Joined
- Oct 2, 2015
- Messages
- 3,565
- Reaction score
- 770
- Points
- 113
I am in the process of buying the oil and oil filters for completing my re-build (hopefully this month - November). The items which touch the oil and I am unsure of their impact are:
1. I have a syringe with some first start oil for the turbo which I assume I just put into the hole for the oil feed before connecting it?
2. Tuffty Advised leaving the injectors disconnected and turn the engine over a few times to circulate the oil (I will probably re-check the level - after this before connecting the injectors again)
I read something about using mineral oil for literally 10 mins running on the Driveway? then change filter and oil? is this right, or should it be the normal oil? Should I add an engine flush with the first start?
Thanks for any advise - I am going the GSF tomorrow so will probably pick up the supplies then, but wont be ready to start for a few weeks still, so not that much of a hurry just trying to take advantage of the GSF60 code.
- skimmed degreased head
- new exhaust valves
- relapped inlet valves,
- new rings (hopefully gapped correctly <-- my actual biggest fear)
- new big end bearings
- new sump
- new rods
- cleaned cam cover
- new turbo CHRA
- new PCV pipework / delete with catch can
- new head and rocker gaskets
- cleaned oil pickup
