Right, following on from my last thread, to keep it short
My DSG box (54 a3 2.0 tdi 140) was leaking dsg oil due to physical damage from previous owner letting the flywheel smash the bell housing apart
Box ran/drove absolutely fine, did several hundred miles in it (leak was approx 100ml over 500 miles) But obviously wanted it fixed
Sourced a replacement of the same code (GYN) that had no mechatronics, removed my box, removed mechatronics (carefully) and fitted into the new box, filled with new oil and filter.
Fitted back up, went to drive car, got to 30mph and car dropped out of gear and PRNDS flashes with no drive
Have following codes
inplausiable mechanical gear disengagement p2711 no commuction/signal
Implausianle mechanical gear disengagement p2711 no basic setting/adaption
So put car on recovery truck and took to a friend, plugged in vagcom, did adaption, brought car back to mine to carry out test drive. Same thing happened again with same codes.
I’ve since
Removed mechatronics again, no damage was present (to double check)
Swapped the input shaft speed sensor to one from my old box
Swapped oil pump to one from old box
No changes at all, completely out of ideas, this new gearbox has only 70k miles on it, so I’d be surprised if it’s the clutch packs? Feels really tight when I can use it, but always drops out of gear between 30-40ish irrelevant of what gear I’m in.
To add, I can floor it in first/second and there’s no clutch slip etc, picks up and pulls hard.
No idea where to go from here?
I’ve since
