Okay, soooo in my suspension adventures ..........
I found out the following.
Regarding USDM and Canadian A3 8P 2.0T Quattro facelifts (we only got sportback and with the Quattro we only got 2.0T from 2010 til 2013).
Basically a lot of these cars have excessive front wheel gap from factory. Someone measured 0.75" more up front than back.
Our North America cars also have springs that are different and softer and higher compared to euro versions of these cars.
So basically I always hated the odd look the bigger front wheel gap created, and that's why I lowered my car in the first place .... Although lower and less wheel gap is nice .... I do like stock ride .... And I am pretty sure NA cars have a way softer ride than euro A3's of this spec.
Soooo I lowered.
Wasn't happy .... Again and again and again .... Finally I thought up an idea .... Euro S3 8P's have springs from eibach made for just lowering the front to equal it out .... Well I thought, if I could find a spring to do this from cross platform than I could run my OEM rear springs and run an OEM front that was just lower but same rate.
Than I'd have stock ride right?? Well no but I'll explain that later.
Basically I found that USDM golf R front springs were basically the same spring rate if not slightly softer than the OEM springs on the front of my car. They were also lower about 0.70" roughly. Happy me .... This was after much trial and error .... Also bought some GTI springs which definitely would have been lower and worse ....
So I installed my OEM rear springs again .... And installed the USDM golf R front springs .... BINGO!!!!!!
CAR IS LEVEL FRONT TO BACK!!!!
HAPPY ME!!!!
Unfortunately the ride wasn't good because I ran the wrong dampers .... damnit
Butttttt .... Moral of my story is .... If you own one of these cars, then do a little cross platform looking when wanting to change something.
Especially if you own a North America one of these cars with excessive front wheel gap!!!!
Now I'm back on lowering springs haha .... Because I like it a little lower .... But rides like stock because I put the stock dampers back on, which are quality and absorb bumps way better than my last dampers did.
So if you don't wanna change much .... Just change the fronts for some looks
*this very likely doesn't apply to euro cars.
*Some rare cars I've spotted are equal front to back cuz they have higher rear springs from factory .... Very very rare.
Sent from my highchair using Tapacar
