2011 s3 concert to rns-e
Seary1996
Liverpool
do I need to buy the connections adapter or will it just plug in to the original cables, and will it need to be coded on vagcom?
I did this with mine. Plug & play, no coding needed.
I needed an adaptor as I installed a Bluetooth unit at the same time.
It’s Bose, I think I moved a wire in the terminal block for the aux.
Bluetooth fairly easy, need some trim off to run mic to overhead area.
