- Joined
- Apr 28, 2015
- Messages
- 130
- Reaction score
- 62
- Points
- 28
One thing I missed after having owned an A3 8V was the passenger mirror dip on reverse. The A3 8P never had this option, but the highline door control modules do support it. The idea originally came from this forum thread.
Mirror adjustment motor:
The 09-10 A3 8p facelift mirrors ("dumbo") are equal in shape to early A4/A5 B8-series and A6 C6 facelift. The mirror adjustment motor in the A3 8P has part number 8T0959578 (LHD) / 8T0959577 (RHD). This is the 3 pin non-memory version. But i.e. Audi A6 was also offered with option code 6XL (Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable/heated), which includes a version of the mirror adjustment motor with memory function. This motor has part number 8T0959578A (LHD) / 8T0959577A (RHD) and 8 pin connector.
Door control module:
You need a highline ("MAX") passenger door control module. 8P0959802J, M or P. The standard ("MIDI") modules do not have the pins needed for this option to work. Pin out is the same as Golf/Jetta MK5
16 Pin Connector (Generation 3) – MY07 onwards
1 – vertical adjustment potentiometer (mirror) – models with automatic mirror adjustment
2 – vertical adjustment potentiometer (mirror) – models with automatic mirror adjustment
3 – horizontal adjustment potentiometer (mirror) – models with automatic mirror adjustment
4 – mirror adjustment motor (12v)
5 – mirror ground
7 – Mirror heater (12v)
8 – auto dazzling rear view mirror exterior
9 – horizontal adjustment potentiometer (mirror) – models with automatic mirror adjustment
10 – entry light (12v) shares ground with 11
11 – mirror heater (ground)
12 – mirror adjustment motor (12v)
13 – indicator (12v) – shares ground with 11
16 – auto dazzling rear view mirror exterior
Acquire parts and to the following:
- Remove passenger door panel, door control module and window frame (to make mirror removal easier)
- Remove mirror incl. wiring (Torx T30 hidden behind plastic cover)
- Remove mirror glass by pulling outwards with gentle force
- Remove mirror adjustment motor (small Torx in center and 2 small clips)
- Pull mirror cap upwards (a few clips to loosen) and remove lower plastic cowl
- You're now able to pull the wiring almost all the way through the mirror pivot
- Insert 4 repair wires through the rubber sleeve (I used 5 for future ambient light mod) and pull back wiring. This is the hardest part, but eventually you'll be able to get the new wires all the way through.
- Cut away old 3 pin connector and attach crimp terminals to all 7 wires (000979009E)
- The 8 pin connector to fit the new motor is not available for purchase. You can use a 12 pin connector from a Quadlock connector and reduce it to 8 pin size, and it will fit perfectly!
- Attach 4x crimp terminals to the door control module end and pin connectors according to the following wiring diagram:
Passenger door mirror should now dip when reverse gear is engaged if mirror adjustment knob is in R position (LHD) or L position (RHD). Mirror will return to normal position when car moves forward, ignition off or when adjustment knob is turned to another position.
5 – mirror ground
- LHD:
Mirror end - Door control module
1 – 2 (vertical adjustment potentiometer)
2 – 4 (mirror adjustment motor +12v)
3 – 1 (vertical adjustment potentiometer)
4 – not used
5 – 3 (horizontal adjustment potentiometer)
6 – 5 (mirror ground)
7 – 9 (horizontal adjustment potentiometer)
8 – 12 (mirror adjustment motor +12v)
- RHD:
1 – 3 (horizontal adjustment potentiometer)
2 – 12 (mirror adjustment motor +12v)
3 – 9 (horizontal adjustment potentiometer)
4 – not used
5 – 2 (vertical adjustment potentiometer)
7 – 1 (vertical adjustment potentiometer)
8 – 4 (mirror adjustment motor +12v)
- Module 46 (CECM): Coding, long coding helper, byte 11, activate bit 7 ("Mirror lowering with reverse gear")
- Module 52 (passenger door): Coding, use value from your old module and add +256 ("Seat memory AND/OR Mirror with memory function installed"). I.e. 0000252 + 256 = 0000508.
