It sounds like I have a rattle can in my boot and randomly when going round corners or braking hard it sounds like the metal ball in the can moving around, my boots empty and I’ve removed the spare and tools but it’s still there. Any ideas?
Thanks for suggestion, checked tyres this afternoon and can’t see anything in them, the cars just gone 2 years old so I don’t think it’ll be a bearing. Back to head scratching.Nail in tyre? Wheel bearing?
I wonder if that’s my issue, how easy is it to remove the rear seat?A puzzle. I dropped a screw down the gap where the seat belt buckle comes out from the rear bench seat. Drove me nuts. Had to take out the rear bench seat. Found screw. Noise gone!
Screw was under here, rolled around when braking etc
Yeah i might do that first, means giving the Mrs my keys though!!No problem. Before you pull the car apart maybe go out with a passenger who can try to locate where the noise is coming from. It's almost impossible whilst driving. Even better someone else drives and you try to locate the source of the noise.
She drives it brilliant if I’m totally honest, like you say I just want to fine out what it is.It's a sacrifice that's worth it to cure the noise.......
I take it that you’ve previously dropped something in that area then, otherwise you’ll be ripping out the rear seats for nothing and could potentially cause some damage.I wonder if that’s my issue, how easy is it to remove the rear seat?
If you haven’t then think carefully before removing the rear seats, something could break and all for nothing.
If you HAVENT dropped anything in that area then chances are you are barking up the wrong tree.
I've only had the car since June so I was thinking maybe the previous owner had, I'm going to get the wife to drive it around for a bit while i sit in the back and hopefully track it a bit better.I take it that you’ve previously dropped something in that area then, otherwise you’ll be ripping out the rear seats for nothing and could potentially cause some damage.
