Hi all,
Got into car from work this evening, started car, jumped out for 1 minute and got back in to see DTC fault message on dash with DTC light lit. Turned car off and on and light cleared.
Got 15 mile/30mins down road and same lights came on again. Switch off and on resolved.
Anyone had this or know of any common fault which causes this before you read below? Car is a 2015 SQ5 TDI.
Ran VCDS fault reader when got home and have several faults including;
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: Malfunction 0010
with the majority of these referencing this particular fault code - 00778 Steering Angle Sensor (G85);
e.g.
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8R0 907 379 BA HW: 8R0 907 379 BA
Component: ESP8 quattro H09 0020
Revision: -------- Serial number: --------------
Coding: 249DCC01
Shop #: WSC 06335 000 00000
VCID: 8009765B1381511E1BD-80D5
1 Fault Found:
00778 - Steering Angle Sensor (G85)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 18
Mileage: 57460 km
Time Indication: 0
Date: 2018.12.13
Time: 18:58:41
Freeze Frame:
Hex Value: 0x0500
Hex Value: 0x4082
Hex Value: 0x022F
Hex Value: 0x23B2
Hex Value: 0x0000
Anyone any ideas? Any help much appreciated folks! Thanks
e.g.
Coding: 249DCC01
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 18
Mileage: 57460 km
Time Indication: 0
Date: 2018.12.13
Time: 18:58:41
Freeze Frame:
Hex Value: 0x0500
Hex Value: 0x4082
Hex Value: 0x022F
Hex Value: 0x23B2
Hex Value: 0x0000
