Audi A4 concert radio
Just hold the < or > button for about 2 or 3 seconds and then it should allow you to manually tune into a frequency.
hth
Ive
hth
I've tried holding < and > separately but it still doesn't manual tune the frequency
Apologies for the late reply... So here’s what you need to do (assuming your controls are on the centre dash like mine?):-
1. When on ‘Radio’ mode, the screen will show 4 options... bottom left is ‘Tuning’. 0A37C5AA 120C 4F15 90A2 9BDD0FB3F6B5
2. The 4 options (Memory, Waveband, Tuning & Sound) all refer to the buttons around your centre thumb wheel, so press the bottom left button on here.
535E2999 EB14 4413 9DDA 0B6DB29BA9C8
That will bring up this screen.EC6C6C12 6A25 4B53 ABE9 69A661CB9741
3. Press the centre thumb wheel to select ‘tune’ as it’s highlighted white.
92A23DB0 9F58 4333 B2CA 3EBB774B6018
This will turn ‘tune’ dark orange.
4. Turn the thumb wheel to the left or right (depending on the number you want to achieve). This will adjust the frequency by .1 for every click.
DE37C5E2 7812 4E4A 9C50 A6A6D3EB1440 3320208B E2EE 45F1 A160 6BBB55515C8E
Once you reach the frequency you require, it will either come up with the channel name in the bar or the number followed by MHz.
5. Once you have your chosen frequency, press the thumb wheel again, which will remove the dark orange & will allow you to then turn the thumb wheel to choose the other options.
5025B809 31C4 4EDE 8D19 034149DBE14F
6. Turn the thumb wheel right 2x clicks until ‘store’ is highlighted white.
2C8C804C 8347 4A18 855B CE0C26719802
7. Press the thumb wheel to then bring up this screen.
EDC79F0F 7BBF 4D67 8C45 08EC30104C8F
Choose the location number you wish to place the station.
8. Press the thumb wheel & this message will appear.
F6522C95 431C 47A7 AB1D F7824D5DE7F9
To access the saved station at any time of you aren’t on it, you just click the top left button to select ‘memory’ (when in radio mode) & it should be there when scrolled to your chosen location number.
