Permanent failure | faultcodes S4 B9
Rogier140
Netherlands
Hi all,
I drive a audi S4 B9 (2017). It is an full option car from Germany.
The car had of and on fault issues with several systems. Also during driving sometimes a drivetrain failure pops up. When restarting the car or leave it for a day the faults were gone.
I went to the dealer to adress these issues. They said the have no record of others having simulair issues.
They updated the Canbus software. That resultet in permanet failure of all the systems, even when restarting.
Are some of you having the same with the B9 platform ?
From the look of those warning lights I'd say the car should not be driven. Call out Audi Assist, I'm assuming you have this in Germany, and have the car recovered to a dealership. Then refuse to accept it back until all issues are resolved...
Reactions: WesT-gefül
Crazy. Hopefully you get this sorted.
Crazy indeed. I got the car like this from the dealer without warning.
I needed to disassemble the aftermarket alarm first before they go further. The alarm wasn’t connected at the Canbus at all....
It is going back to the dealer tomorrow again.
Im from Holland btw
No installed by a pro and used one like this on an other car. It does not even have any connection to canbus. It only uses power.
Reactions: cuke2u
No dealer ever has any record of any fault ever happening on any other car. Audi's are perfect. If you car has a fault then the fault is yours.
Seriously though in your place I'd be considering rejecting the car.
Solved already?
Al opgelost? Stuur me anders even een PM.
Rogier, I've had 3 times the "Differential" fault combined with an "Electrical".
Goes away when restarting.
My car same as yours, with Ingolstadt plates (from factory).
So who knows of a genuine risk to publicising license and/or VIN?
https://www.google.co.uk/search?sou...i10i30j0i13i10i30j0i13i30j0i22i30.wINwOoLsKnQ
I read an article where a owner had been sent tickets for all kinds of things amounting to thousands of pounds, just because his plates had been cloned. It is well known that car thieves can cloned VIN number and matching number plates and put them on identical vehicles.
https://www.google.co.uk/search?ei=...3i13i21j33i160j33i10i21j33i10i160.a2fyJb_jLuA
It may never happen, but there is no harm in just being cautious.
Vin number removed
Reactions: cuke2u
Well I got the car back from the dealer. They updated the controller software and all faults cleared.
Reactions: cuke2u
Lady and Gents. and specially @Rogier140:
Today I had the same, out of the blues at aprox. 50mph diff + electrical fault = 2 first pictures.
Pulled over and idling was at 1000rpm = 3rd. picture.
Switched off ignition for 1 second, then switched on and all faults gone. Idling back to normal 600rpm = 4th picture.
20190107 IMG 8600
20190107 IMG 8601
20190107 IMG 8605
20190107 IMG 8606
Solved already?
Opgelost en is inmiddels wet terug op de “normale” manier....
Bij starten alles foute boel .... even later herstarten en probleem is weer weg .....
Ben dan benieuwd welk software update zij uitgevoerd hebben. Toevallig een lograpport van je auto?
A3 8V Facelift Limousine
Nee helaas . Ze hebben eerst een canbus update gedaan waardoor ik permanent de foutmelding had. Afgelopen week hebben ze een update gedaan op het regelapparaat waardoor de foutmeldingen weer verwijderd konden worden en alles weer met elkaar communiceert. Nu heb ik eeer de normale situatie dat met regelmaat foutmeldingen optreden en weer weg zijn bij een herstart .
Werk je bij een dealer ?
12K
9K
