anyone be able to help a friend with these error codes on his golf r.
Log posted below:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZEW305142 Mileage: 56807km-35298miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00322466050B2004
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
ROD: EV_ECM20TFS0205G0906259B.rod
VCID: 2D7FC5DF7C1A0E2240-8078
6 Faults Found:
17789 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [101] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 56783 km
Date: 2019.01.09
Time: 19:11:24
Engine speed: 1025.25 /min
Normed load value: 2.7 %
Vehicle speed: 0 km/h
Coolant temperature: 65 °C
Intake air temperature: 49 °C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 11.601 V
Unlearning counter according OBD: 40
Engine: operating status: IS
Engine temp. management actuator: raw value: 1586
Engine temperature management actuator: stop open: 135
Engine temperature management actuator: after-run stop: 3956
RVC_SP: 164.50 °
RVC_AV: 96.84 °
RVCPWM: -100.000 %
15462 - Control Circuit for Coolant Bypass Valve
P2681 00 [040] - Open Cricuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Mileage: 56490 km
Date: 2018.12.30
Time: 17:27:21
Engine speed: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 17 °C
Intake air temperature: 19 °C
Voltage terminal 30: 11.699 V
Engine: operating status: ES
Engine temp. management actuator: raw value: 1474
RVC_SP: 88.75 °
RVC_AV: 89.23 °
RVCPWM: 0.000 %
15470 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 56783 km
Date: 2019.01.09
Time: 19:11:26
Engine speed: 877.75 /min
Normed load value: 4.7 %
Coolant temperature: 64 °C
RVC_SP: 76.78 °
RVC_AV: 96.84 °
RVCPWM: 100.000 %
16986 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56788 km
Date: 2019.01.09
Time: 20:34:02
Engine speed: 837.00 /min
Intake air temperature: 50 °C
Voltage terminal 30: 11.718 V
Engine temp. management actuator: raw value: 1967
Engine temperature management actuator: stop open: 145
Engine temperature management actuator: after-run stop: 3948
RVC_SP: 102.50 °
RVC_AV: 122.16 °
RVCPWM: 100.000 %
16464 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56791 km
Date: 2019.01.09
Time: 20:42:03
Coolant temperature: 98 °C
Intake air temperature: 23 °C
Voltage terminal 30: 12.031 V
Engine temperature management actuator: stop open: 1967
RVC_SP: 5.75 °
RVC_AV: 131.88 °
RVCPWM: 100.000 %
16465 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56807 km
Date: 2019.01.10
Time: 18:00:23
Coolant temperature: 49 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.050 V
Engine temp. management actuator: raw value: 151
Engine temperature management actuator: stop open: 156
Engine temperature management actuator: after-run stop: 151
RVC_SP: 0.00 °
RVC_AV: 0.00 °
RVCPWM: -100.000 %
Readiness: 0000 0000
Log posted below:
Revision: --H13---
6 Faults Found:
P00B7 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56783 km
Date: 2019.01.09
Time: 19:11:24
RVC_SP: 164.50 °
RVC_AV: 96.84 °
RVCPWM: -100.000 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Mileage: 56490 km
Date: 2018.12.30
Time: 17:27:21
RVC_SP: 88.75 °
RVC_AV: 89.23 °
RVCPWM: 0.000 %
P00B7 00 [237] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 56783 km
Date: 2019.01.09
Time: 19:11:26
RVC_SP: 76.78 °
RVC_AV: 96.84 °
RVCPWM: 100.000 %
P00B7 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56788 km
Date: 2019.01.09
Time: 20:34:02
RVC_SP: 102.50 °
RVC_AV: 122.16 °
RVCPWM: 100.000 %
P00B7 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56791 km
Date: 2019.01.09
Time: 20:42:03
RVC_SP: 5.75 °
RVC_AV: 131.88 °
RVCPWM: 100.000 %
P00B7 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56807 km
Date: 2019.01.10
Time: 18:00:23
RVC_SP: 0.00 °
RVC_AV: 0.00 °
RVCPWM: -100.000 %
