phil mcglassup
Hi All,
For a while my Audi A4 B6 1.9 Tdi (2003 with 167k miles) has had an intermittent starting problem. When starting from cold it will start for a split second, the revs reach between 600 and 1200 rpm before stalling. Usually it needs many attempts before it will 'catch' and start, although as the revs begin to rise it runs rough but then runs and ticks over perfectly and will start first time when warm. Sometimes it starts from cold with no issues. There is no engine management light on nor any other warning lights. At the time of typing, it won't start at all !!
I've tried a few things to no avail , i.e. using the spare key, disconnecting the battery for twenty minutes and banging on the ECU (poor relay connection) as these are the things that have been suggested when doing searches. There is one suggestion that it could be the camshaft position sensor as apparently they are prone to failing, but it is a massive job if it isn't the fault!! I changed the cam belt and water pump only 2000 miles ago.
Apart from taking it to a garage, any other suggestions ? I certainly can't compain about the car as it's been very reliable and cheap to run so far !!
Any help appreciated.
