Adaptive lighting fault
vaf888
Hi
Have this fault on my b8.5 S4 2013. Believe it is the NSF rise height sensor.
Has anyone got a part number or can advise if they are easy to fit.
Sent from my Nexus 5X using Tapatalk
Just get under & check directly.
Thanks. Just going to buy one of eBay. Audi want £140 for one.
Just replaced the sensor. But fault is still showing. Does anyone know if it needs some sort of fault clearing from a garage.
Calibration.
Should of diagnosed it fully before condemning as could be number of things.
Garage pulled it as the problem. I think the part is different from the norm as it is for the adaptive lighting.
Looks like I have to suck it up and buy a genuine unit from audu
You're not listening & with respect.
You still have to calibrate when fitting these sensors.
Also, flagging it up & not repairing, urmmm.
Get someone who knows what they're doing to repair it, then you're happy.
Ok Point taken. Thanks
Levelling sensors generally are the same for adaptive & non as the left right is taken from the steering signals, so no need for different sensors & usually its a different levelling module for adaptive, not sensor.
The leveling module code that I removed 8K0 907 503, but the one I installed ends in 825p which is maybe the issue. Does installing the modules require a vcds reset.
Look thanks for all the help.
Is this a module. The lights are moving left right and up down as normal. Does a leveling sensor look different.
That's a levelling sensor, not a levelling module & yes it needs calibrating.
Great thanks. The part code is different to the one I put in. Only realised after removing it. Not sure if maybe this part has been superceeded with the 825 part as it does state it is compatible.
I will ask the garage to calibrate it and take it from there.
NHN
17
7K
mickyh7
M
