Hi all
Recently purchased a s3 8p 2010
Tte 420 and all the supporting mods running around 411bhp.
Gave it in for a health check at vrs Northampton
Ran below power 390 bhp
Got the timing belt and water pump done as the water pump was leaking
Timing chain and tensioner also done with cam follower
Oil service
New dv and a few other bits n bobs
A week later car has started to misfire and also smoking (white/blueish) has a atmospheric r tec pcv delete and it just chucks out fumes of fuel so bad that its visible coming out the bonnet gaps.
Used vagcom and showing cylinder one missfire, swapped the coils still showing cylinder one missfire same with the plugs.
Now I done a compression test (disconnected fuel pump and hpfp) and the results as follow
Cylinder 1 - 50
Cylinder 2 - 150
Cylinder 3 - 150
Cylinder 4 - 150
Dry test
Cylinder 1 when put a bit of oil down showed around 110
Could this be an internal engine problem or should I try changing an injector
Oil service
Cylinder 1 - 50
Cylinder 2 - 150
Cylinder 3 - 150
Cylinder 4 - 150
Dry test
