Barry786
Audi S3 S-TRONIC
Sportback
2014
16k miles
I have just owned this Audi S3 for around 2 months and it's on 16k miles. Enjoy this car very much. Yesterday after a car wash, setting off from traffic lights the car started to judder and the EML was blinking, I pulled up on the side switched the car off and on, everything was back to normal no juddering and no EML.
Car usually drives and pulls in every gear with no hesitation and also starts without any problems.
Quite suprised i'm getting engine problems at 16k miles.
Now i've heard cylinder misfire can be caused by several things such as spark plugs, coils, injectors and so on. I don't want to be replacing everything, can anybody point me in the right direction with the fault codes below.
Sportback
2014
16k miles
Chassis Type: 8V-AU37 (5Q0)
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 HW: 06K 907 425 A
Component: 2.0l R4 TFSI H09 0006
Revision: --H09---
Coding: 0A1D00322426010B2004
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0218V0906259 001008
ROD: EV_ECM20TFS0218V0906259.rod
VCID: 7DF1819EEC109DAC73-8028
8 Faults Found:
17178 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
15290 - Output for Starter Relay
P0616 00 [032] - Short to Ground
15294 - Control Circuit for Starter Relay 2
P3048 00 [032] - Short to Ground
15125 - Cylinder 1
P0301 00 [096] - Misfire Detected
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 26441 km
Date: 2019.02.25
Time: 13:40:59
Engine speed: 1517.50 /min
Normed load value: 18.0 %
Vehicle speed: 28 km/h
Coolant temperature: 105 °C
Intake air temperature: 60 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 13.886 V
Unlearning counter according OBD: 40
Engine: operating status: PL
N_TOOTH: 1514 /min
T_AST_SAE: 3158 s
TOIL: 103 °C
STATE_LS_SAE[1]: CL
FUP_H_SAE: 11590.0 kPa
FUP_EFP_MES: 5293.45 hPa
15128 - Cylinder 2
P0302 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 26441 km
Date: 2019.02.25
Time: 13:40:59
N_TOOTH: 1514 /min
T_AST_SAE: 3158 s
TOIL: 103 °C
STATE_LS_SAE[1]: CL
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 26441 km
Date: 2019.02.25
Time: 13:40:59
N_TOOTH: 1514 /min
T_AST_SAE: 3158 s
TOIL: 103 °C
STATE_LS_SAE[1]: CL
15102 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [096] - -
15094 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [096] - -
Readiness: 0000 0000
Revision: --H09---
8 Faults Found:
17178 - Databus
15125 - Cylinder 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 26441 km
Date: 2019.02.25
Time: 13:40:59
N_TOOTH: 1514 /min
T_AST_SAE: 3158 s
TOIL: 103 °C
STATE_LS_SAE[1]: CL
15128 - Cylinder 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 26441 km
Date: 2019.02.25
Time: 13:40:59
N_TOOTH: 1514 /min
T_AST_SAE: 3158 s
TOIL: 103 °C
STATE_LS_SAE[1]: CL
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 26441 km
Date: 2019.02.25
Time: 13:40:59
N_TOOTH: 1514 /min
T_AST_SAE: 3158 s
TOIL: 103 °C
STATE_LS_SAE[1]: CL
P0068 00 [096] - -
P0068 00 [096] - -
