Put simply... Do not use an atmospheric valve on standard ecu as it will see it as a massive airleak and screw with the way the engines runs as the ecu trys to compensate
You must have been lucky not to notice an issue but a BOV is just a big air leak and the ECU will attempt to correct it.... ME7 is simply not designed to run with an atmos valve
