Rear Brakes
dkingy11
SQ5 & A4 Allroad
So I finally got round to taking my car in for wheel balance today to try and get rid of the rattle but didn’t get them all done (only 3) as was told the LH RR Caliper was seized (they managed to free it but chances are it will seize again) They also said this is probably the cause of the rattle. Basically said it needed a new Caliper, disc & pads. I’m assuming I need to replace both sides (I know I would for discs & pads but wasn’t sure about the Caliper?
Also in addition to the replacement Calipers (photo 1), do I need to purchase brake support plates (photo 2)?
Any help would be greatly appreciated. I’m hoping someone has already replaced theirs!
If just one caliper is seized you can replace it on its own. No, you don't need the carriers. I'm sure the originals are serviceable. Double check the dust boots, and lube the slider pins. Bigg Red are a good source for parts, etc.
As this is an electric handbrake, you need VCDS to retract it, etc.
Do a brake bleed on completion.
