Bought a replacement trim for my A3 Sportback 2010, it looks like it should snap in place (wishful thinking no doubt) but I can't work out how... Does anyone know where I can find instructions? Thanks! Paul
You just need to get a trim tool between existing cover and mirror and lever it off(quite firmly), if your fitted one is damaged then you don't worry too much about marking it more. then the new one will just clip on.
Iirc you need to fit the indicator led using access from inside the mirror. Once the glass is removed you’ll be able to see where to screw it in and also gain access to the plug.
Thanks but indicator is intact and working fine. Just need to get the bottom black trim cover on, I'm sure it's the correct part but lining up all the lugs (no screws/holes) is difficult!
