A small milestone of note
JSR913
North Yorkshire
313 BiTDi , Truro to North Yorkshire today, ACC set at 75 mph results in : -
at Tamworth
IMG 3331
at Home
IMG 3337
Reactions: James.c, NevMan and Bishop187
My CDUC on 20” wont do that but I am usually going south from midlands so maybe is down to midlane hoggers and everything else boiling my blood :D
Well done and jealous on your mpg mate
Reactions: NevMan
Random question, but how do u get your live mpg bar thing to read 60 before the max bit? My 2015 2.0 tdi ultra only goes up to 40 then max.
Is there something in vcds?
Rob
Rob
Are you sure your speedo is in mpg not in l/100km as 40 is the max what it shows in litres per 100 km.
Mines definitely in mpg and only goes to 40 then max..... 0, 10, 20, 30, 40 then max.....
Reactions: Bishop187
Doesn't change even when I'm coasting down hill..... is mine wrong or is it because it's a facelift they changed it?
Mines the same on facelift. Not that I ever get 50mpg
A7 3.0tdi 272 Black Edition Mythos Black Tech pack
30mpg average in my bitdi
40mpg on longer journeys. never ever have i seen a 5*mpg :grumpy:
I've not got into the 50s in a 2.0 but haven't done any long long drives yet. I still want my live fuel efficiency meter to read 60 and not 40.....
Did you get 50+ whilst in efficiency mode?
NOPE!! Sport manual mode :D
Think I've used Efficiency mode twice tops?? Nearly got killed both times as the throttle response is borderline dangerous.
That 50+ was en route to Legoland last year with my daughter :) Was cruising around 75mph as that is pretty much the sweet spot :)
