MMI stuck on splash screen
paul4tune
london
My Audi a5 Sportback MMI is stuck on the below screen after 10 sec or so the screen goes black, I ran a vcds scan and the below errors show up I'm not to sure how to interpret those errors.
can anybody help
things I've tried
fully charging battery
disconnecting amp, the head unit
stripping the head unit down removing hard drive and reassemble
thank you
IMG 2798 2
Optic test
Faultscar
Code:
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4G0 035 056     HW: 4G0 035 056
   Component: Radio U STD   H51 0051
   Revision: AB001007    Serial number: 469H90A7549780
   Coding: 010003020100000001
   Shop #: WSC 06325 000 00000
   VCID: 5EB21651498270BA8F-800A
1 Fault Found:
03278 - Functionality Limited due to Missing Messages
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 61
                    Mileage: 120608 km
                    Time Indication: 0
                    Date: 2010.01.22
                    Time: 00:22:23
             Freeze Frame:
                    Bin. Bits: 00000000 00101100
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 8T2 035 666 F    HW: 8T2 035 666 E
   Component: H-BN-EU       H49 0107
   Revision: --------    Serial number: 475H+0A7556117
   Coding: 01010104000681ED01000B1E000000030000
   VCID: 3E72B6D1A9C250BAEF-806A
   Subsystem 1 - Part No: 8R0 060 884 R
   Component: EUR 2010  1107
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466HX0A0068343
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000600952
   Subsystem 4 - Part No: 8R0 060 961
   Component: CD-Database  1886
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 61
                    Mileage: 120608 km
                    Time Indication: 0
                    Date: 2010.01.22
                    Time: 00:22:23
             Freeze Frame:
                    Bin. Bits: 10110110 00000010
                    Bin. Bits: 00000000 00001110
                    Bin. Bits: 00000000 00000000
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 61
                    Mileage: 120608 km
                    Time Indication: 0
                    Date: 2010.01.22
                    Time: 00:22:23
             Freeze Frame:
                    Bin. Bits: 00100001 00010000
                    Bin. Bits: 00000000 00001010
I've fitted an optical loop on the AMP but still not working, nothing else is connected as the Bluetooth is built inside the MMI head unit
If i knew for sure the head unit had gone id just buy one from eBay but i don't want to throw away money
cleared the faults retested now getting a disk drive initialization error 02445 at address 5F
Updated error 02 Updated error 01
hi did you manage to sort the problem...have the same issue after attempting to install euro firmware in japan mmi...help pleas
820
887
