Hi everyone,
I recently bought Audi A3 and I am veeery satisfied about it. Running very smooth and don't have any problems but, recently yellow engine bulb on instrument table pops up. Nothing else happened and the car is driving fine but the bulb is still there. I connected VCDS and see all the trouble codes and got this. Any help would be great.
Thank you
Chassis Type: 8V-AU37 (5Q0)
3 Faults Found:
17158 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
18111 - Oxygen (Lambda) Sensor B1 S1
P2237 00 [237] - Pump Current Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [032] - -
1 Fault Found:
13637426 - Databus
U1123 00 [008] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 179
Mileage: 157314 km
Date: 2019.05.14
Time: 00:01:04
Thank you
3 Faults Found:
17158 - Databus
U0428 00 [032] - -
1 Fault Found:
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 179
Mileage: 157314 km
Date: 2019.05.14
Time: 00:01:04
