GLOW PLUGS TDI -PD/INTAKE MANIFOLD SENSOR
vw754
vorsprung Durch Technik
U.K
IF GLOWPLUGS ARE STAYING ON,WOULD: 1. CAR USE MORE FUEL?
2. WHAT WOULD CAUSE THIS?
ALSO IF INTAKE MANIFOLD PRESSURE SENSOR IS FAULTY,WHAT WOULD THIS CAUSE?
A4 1.9 TDI -PD 2001 (B6)
If the plugs stay on it would not use any more fuel at all, it would wear out the glow plugs. They should only come on for a few seconds,when you put in the key and when you open the door getting into the car.The intake manifold sensor which is on top of the intercooler would make the car a bit slower a tiny bit smokey but not obvious and drink diesel.This happened to me a few wks ago the car just goes to a set setting on the ecu as it cant measure the correct pressure ,the bumper will need to come off i think.I got away with just taking out the passenger headlight but mine is 2.5 so what makes tou think this sensor is gone faulty.Have you checked your diesel cooler under the car for leaks.or exhaust for cracks or damage:idea:
done everything! 26/27 mpg driven steady. new maff,coolant sensor,all pipes checked for splits,no leaks,no fault codes. Car has brilliant performance,just drinks alot of diesel. Did yours drive/run ok? also how did you find out it was your manifold pressure sensor? mine is a 1.9 tdi,sensor located on intake pipe,near bulkhead.
WHAT WERE YOU GETTING TO THE GALLON?
CANT SEE ANY,ANYWHERE. NOTHING ON FLOOR OR ENGINE BAY:confused:
VW754
as a fellow stokey Ive dne some asking about for you.
A mate of mine is one of the partner's at a porche tuning place, Ninemeitser in warrington and he recogn's the best bloke around here for VAG diesels is Andy at PSI tuning in chesterton.
If my mate Mark rates him then I have to presume he's good
there number is 563703
tell him you got his number via a mate of Mark Clowes
Simon
thanks for the info,i know andy...gud lad, he's confused with this one aswell!,thanks,
see what else you can do,thanks again
p.s timing checked and its spot on! :wtf: is it? next is to flash ecu with oe spec ,just in case.
I
22
3K
950
