Comfort windows
Seantdi
Age
41
Ireland
Can anyone tell me if the drivers window should auto lower when the switch is pushed down fully?
All other windows do it except drivers.
It will go up auto when the button is pulled fully up..
I thought it use to do it but doubting myself now!
Any help welcome.
Yeah it should do, the switch could be faulty or I'm sure I've read you need to reset them under certain circumstances, give it a search it might throw something up.
Sent from my moto e5 plus using Tapatalk
Reactions: Seantdi
Have done that. Made no difference. It will go up no problem just not down..
There is a process to reset it, for some reason I’ve got 6 seconds as the number in my head but could be wrong, could be more or could be less?
Hold the button down, keep held down for 6 seconds once fully open, then, hold the button in the close position and keep held for 6 seconds once it reaches fully closed.
As above. I have tried it. Won't work
As above says pull it up and hold it up, which, if it is just a reset that is required won’t do anything without the pushing it down and holding it down bit first.
Jakm15 suggested they needed to be reset. Which I have done and still nothing.
You just explained how to do a reset. Hence "as above"
852
19
31
6K
