eastcruisers
- Joined
- Jun 26, 2016
- Messages
- 26
- Reaction score
- 7
- Points
- 3
- Age
- 39
I think i saw carbon fibre caps you can stick on or remove and replace but i can't find them anymore for.my self as i have a ant sized rust dot on one of mine. Other than that its just a matter of removing them sand down prime paint and lacquer or powdercoat which is better, may have to drill out the rivets though unless you have screws holding them in.evening,
the side window trim on my s3 has peeled. It looks like its riveted into the door - so not easy to remove. any suggestions how to resolve?
thanks. how did you remove and refit?The trim on mine started to flake off pretty bad so I took mine to a wrapping company where I had limitless options to re-trim it.
I did however go for a standard Matt black as it matched the rest of the car and only cost me £30 - £40.
That was four years ago and you couldn't tell that it wasn't standard trim.
Aernt you lucky, facelifts are all riveted in which suckssssNo rivets on my 57 plate A3, just screws. I've wrapped one side myself in black and it looks great......couple of quid for vinyl wrap from eBay, then about an hour of my time using my wife's hairdryer applying it. Will do the other side when I order some new wrap.
Gaz
