Chrome trim
HOGG
GB
Could you remove the chrome trim that I have highlighted below and still drive the car or is it part of the window/door seals?
Thanks peoples. I'll try and ask less questions once I know more about the b7
Sent from my SM-G930F using Tapatalk
I’m no help but would also like to know if it can be removed without leaving gaps etc as I hate mine.
I believe its rivet on so to remove is a massive job most just have it wrapped or painted in place
Reactions: Charlie Farley
Being a painter id advise against painting them, if you cant get them off without it being a ball ache you wont get the paint round the edges enough let alone being able to key it up enough for the paint to stick without using a roll of duct tape to prevent accidentally damaging the bits you want to keep shiny.
id say get them wrapped it will probably last longer if you use a good company as a pressure washer will end up taking the paint off eventually especially if you clean it often, i did the chrome on my old benz and i thought i did a good job or as good as i could being on the car i used a plastic primer, etch and 2 pack paint to be on the safe side and it lasted a year and looked terrible and caused myself more work to get it back to original.
A wrap sounds like the ideal solution
Its a wrap then..lol
Reactions: AvantMike and martin1984
i'm still a 20 year old just trapped in an old guys body....but it does have its plus points..lol
Reactions: martin1984, HOGG and Ricky Burrows
I'm the same. I'm trapped in a body double my age
The door weather strips have clips on the inside, and the frames need to be removed to gain access.
I believe the upper trim is riveted from the inside and the small section beneath the rear 1/4 glass simply unclips from the outside.
A stupid way of fixing them but i guess thats just Audi for you!
Best option is to have them wrapped although not a permanent fix, over time you may have lifting issues.
Reactions: Ricky Burrows
12
722
622
9K
