Scanned my 12 plate B8.5 Allroad and there's two errors. Anyone care to elaborate as to what they are please? I've cleared them, but would like to get to the bottom of what's triggering them? Car drives fine and no noticeable issues.
Sunday,30,June,2019,16:39:44:49227
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: N/A License Plate: 2012
Mileage: 91810km-57048mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 20 42 44 46 52 53 56 5F 62 69 72
VIN: N/A Mileage: 91810km-57048miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 KD HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9977
Revision: 45H25---
Coding: 32194012243601080000
Shop #: WSC 62265 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018KD 003004
ROD: EV_ECM20TDI01103L906018JG.rod
VCID: 76B6EF5B184B3907B41-8022
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8K9 907 379 G HW: 8K9 907 379 G
Component: ESP8 quattro H09 0070
Revision: -------- Serial number: --------------
Coding: 069544
Shop #: WSC 45553 000 1048576
VCID: 46D65F9B28ABE987E41-8012
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 EE HW: 8K0 907 064 EE
Component: BCM2 2.0 H10 0530
Revision: 00002001
Coding: 03B20000000000000000
Shop #: WSC 06335 000 00000
VCID: 77A8E25F1FC1400FAF7-8022
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0811000213602021
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2311000300701016
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 AC HW: 8K2 820 043 AC
Component: KLIMA 3 ZONEN H04 0123
Revision: D0000000 Serial number: 01291220110026
Coding: 342402E080
VCID: 6A8ECB2B5C73EDE7209-803E
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 AJ
Component: BCM1 1.0 H14 0103
Revision: 09014001 Serial number: 00000022413701
Coding: 260080108074AFE00481408000001D0D0F9DA70827090201000008000400010200020020000000
Shop #: WSC 00186 785 00200
VCID: 7AAEFB6B2CD35D67D09-802E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 131211 H06 0070
Serial number: SWF11120135403
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0001
Serial number: 20105049
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000912111410
Subsystem 4 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0021
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 583843E5000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H45 0610
Serial number: 003KFD905PW-
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 57714 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 48CA51A3223FFFF716D-801C
Crash sensor for side airbag: driver side:
Serial number: 6334MSME67724569J
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME68550D3BP
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME7664504EN
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME72654068G
Crash sensor for front airbag: driver side:
Serial number: 63732SME5E684972B
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME0566214AY
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20111221000037
Coding: 000017
VCID: 4FF87ABFC7D128CF577-801A
Component: E221 - MFL H03 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 982 B HW: 8K0 920 982 B
Component: KOMBIINSTR. H16 0640
Revision: 00100000 Serial number: M3B516FDC
Coding: 332529020A012600010000
Shop #: WSC 06335 123 12345
VCID: 3330164F4B396C2F53F-8066
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 88488 km
Time Indication: 0
Date: 2019.03.30
Time: 15:18:07
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 D HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H10 0025
Revision: 1Z070014 Serial number: 1441Z11B170022
Coding: 00CF07FF00
VCID: 40DA49830A8FC7B7DED-8014
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8040
Serial number: 2248456201
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11349000532021200181
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 77
Mileage: 89190 km
Time Indication: 0
Date: 2019.04.15
Time: 14:16:37
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.00 V
Count: 9
Bin. Bits: 00000
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02029164747464545425363E00
VCID: 7CA2FD7326E76357C25-8028
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 P HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000019924132
Coding: 011C02204001410001
VCID: 4DC460B7CDDD1ADF25B-8018
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0018275610
Coding: 100000010001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 343215534EB76B174A5-8060
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0165755902
Coding: 013B062220B900548020023680000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS150 H08 0043
Subsystem 4 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J394 PS240 H08 0043
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 P HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000019936511
Coding: 011C02204401410001
VCID: 4CC26DB336C713D7325-8018
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: EPB-4 H01 0001
Revision: -------- Serial number: 30000000009839
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU48.rod
VCID: 36362F5B58CB7907741-8062
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 E HW: 4G0 035 061
Component: Radio U DAB H60 0099
Revision: AB001007 Serial number: 109L30B7541767
Coding: 010103020100000001
VCID: 1F18EAFFD7B1D84F877-804A
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 666 A HW: 8R2 035 666
Component: H-BN-EU H43 0467
Revision: -------- Serial number: 066L20B7506178
Coding: 10010105000681ED0580AB5E00000403E40000020000000000
VCID: 3728225F5F41800F6F7-8062
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130LD0BS081781
Subsystem 3 - Part No SW: 8T0 919 611 B HW: 8T0 919 611 B
Component: E0380 Bedient H02 0020
Serial number: 00000001025324
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
1 Fault Found:
02067 - Optical Databus; Unpermitted Wake-Up Request
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 77
Mileage: 89190 km
Time Indication: 0
Date: 2019.04.15
Time: 13:10:28
Freeze Frame:
Voltage: 12.10 V
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000019919468
Coding: 010C02204001210001
VCID: 43D0468F1B99DCAFC3F-8016
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 Anhaenger H09 01000100
Revision: 1A001001 Serial number: 00000181546479
Coding: 0100000000000000
Shop #: WSC 00000 000 00000
VCID: 36362F5B584B7907741-8062
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000019919465
End----(Elapsed Time: 02:29, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
www.Ross-Tech.com
Revision: 45H25---
Coding: 069544
Revision: 00002001
Coding: 342402E080
Coding: 00FD11
Coding: 02005D
H01 0021
H01 0031
Coding: 000017
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 88488 km
Time Indication: 0
Date: 2019.03.30
Time: 15:18:07
Coding: 00CF07FF00
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 77
Mileage: 89190 km
Time Indication: 0
Date: 2019.04.15
Time: 14:16:37
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.00 V
Count: 9
Bin. Bits: 00000
Revision: AA001002
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 77
Mileage: 89190 km
Time Indication: 0
Date: 2019.04.15
Time: 13:10:28
Freeze Frame:
Voltage: 12.10 V
No Faults Found
