hello, do heated mirrors only operate under a certain temperature? Because I’ve moved the switch to 6 o’clock and they don’t come on & they aren’t coming up on the fuel saving screen on the dash like they normally do either.
As @HertS3 said I done the same this morning, if the dial is on the heated mirror section they'll work. Sounds like yours might have a fault if they don't appear to be working.
It was about 17 degrees here last night, so I went out and I sprayed water on the mirrors and they started to work. I’m going to try them again soon as it’s raining here. So I’ll let you guys know what happens
