VagManScoop
Hi all. I have owned this car for a while now and have viewed here for tips along the way, great site! But now I'm faced with a misfire problem and would like the experience of you top people to help here.
My problem is a misfire on very steady acceleration and it sometimes cuts out when I let the revs drop too quick. No3 injector was showing an intermittent misfire and so was replaced with the injector loom but the fault is still present.
--Things I have checked--
Fuel colour in filter (new filter fitted)
Injector clearances
Inj harness resistance (all 0.4-0.6 ohms)
Injector resistance (all 0.2ohms)
Cam lobe and rocker wear - OK
ECU visual inspection for water ingress - OK
--Things to check--
Engine timing
Fuel pressure, ign on, cranking, running
Swapping 2 and 3 injectors over
VCDS
Here's my interpretation,
Inj quantity and switch time is the requested by the ecu with actual value being added/subtracted?
Any help here would be greatly appreciated as I don't want to shell out £366 per injector if I don't need one!
Thanks in advance guys!!!
Injector clearances
--Things to check--
Engine timing
VCDS
