Well, I thought I might have been going mad here, so I just checked on elsawin to see exactly what the procedure is for an S3!!
It's exactly the same as on an A3, and in both cases there is no mention of clutch bleed nipples or even touching the hydraulic clutch system.
It looks like quite an involved process IF the brake fluid reservoir has run empty. I've copied the text here, namely:-
"Pre-bleeding
- [SIZE=-1]‒ [/SIZE]Connect up brake filling and bleeding appliance VAS 5234 or V.A.G 1869 A.
- [SIZE=-1]‒ [/SIZE]Open bleed screws in prescribed sequence and pre-bleed brake calipers.
- 1 - Simultaneously bleed both front left and front right brake caliper
- 2 - Simultaneously bleed both rear left and rear right brake caliper
- [SIZE=-1]‒ [/SIZE]With bleeder bottle hoses attached, leave bleed screws open until the brake fluid which emerges is free from bubbles.
Bleeding
→ Display on VAS 5051:
- [SIZE=-1]‒ [/SIZE]From list -1- select diagnosis function "04 - Basic setting".
Note:
ABS warning lamp flashes in the course of the following operations.
- [SIZE=-1]‒ [/SIZE]Use keypad -2- to enter "001" for "Display group number 001" and confirm by touching Q key.
- 1 - Basic setting
- 2 - Display group 1
- 3 - Press and hold pedal ...
- [SIZE=-1]‒ [/SIZE]Press pedal firmly and hold in position.
- [SIZE=-1]‒ [/SIZE]Pedal sags, hydraulic pump starts up briefly, pedal returns
- 3 - Release pedal; FR/FL bleed screws OPEN <>
- [SIZE=-1]‒ [/SIZE]Release pedal, open front bleed screws.
- [SIZE=-1]‒ [/SIZE]Touch s key to switch to display group 002.
- 1 - Basic setting
- 2 - Display group 2
- 3 - Please wait .. (10 sec.)
- [SIZE=-1]‒ [/SIZE]Wait 10 seconds.
- [SIZE=-1]‒ [/SIZE]Hydraulic pump starts up briefly
- 3 - Press pedal 10X; bleed screws CLOSED <>
- [SIZE=-1]‒ [/SIZE]Press pedal 10 times, close front bleed screws.
- [SIZE=-1]‒ [/SIZE]Touch s key to switch to display group 003.
- 1 - Basic setting
- 2 - Display group 3
- [SIZE=-1]‒ [/SIZE]Repeat bleeding procedure as described above.
- [SIZE=-1]‒ [/SIZE]Touch s key in each case to switch to next highest display group until display group 17 is reached.
- 1 - Basic setting
- 2 - Display group 17
- 3 - Partial bleeding over ...
- [SIZE=-1]‒ [/SIZE]Terminate function "04 - Basic setting" by touching ◂ key.
- [SIZE=-1]‒ [/SIZE]From list -1- select diagnosis function "06 - End of output".
- [SIZE=-1]‒ [/SIZE]Switch off ignition and unplug diagnostic connector when this display appears.
- [SIZE=-1]‒ [/SIZE]Brake system must then be bled
Special feature of right-hand drive vehicles:
→ If one chamber of brake fluid reservoir is completely empty, brake master cylinder must be bled at bleed screws -arrows- on completion of basic setting."
If your reservoir hasn't run dry, this appears to be the basic procedure, again copied from elsawin:-
"Special tools and workshop equipment required
- [SIZE=-1]◆ [/SIZE]Brake filling and bleeding appliance VAS 5234
Or
- [SIZE=-1]◆ [/SIZE]Brake filling and bleeding appliance V.A.G 1869 A
Sequence of operations
V.A.G 1869 A.
- [SIZE=-1]‒ [/SIZE]Detach protective cap at bleed screw of brake caliper and attach bleed hose of bleeder bottle to bleed screw.
Bleeding sequence
- 1 - Front left brake caliper
- 2 - Front right brake caliper
- 3 - Rear left brake caliper
- 4 - Rear right brake caliper
- [SIZE=-1]‒ [/SIZE]With bleeder bottle hose attached, leave bleed screw open until the brake fluid which emerges is clear and free from bubbles.
- [SIZE=-1]‒ [/SIZE]Press brake pedal 5 times to assist bleeding process. [SIZE=-1]‒ [/SIZE]Tighten bleed screw to 10 Nm, detach bleed hose and attach protective cap to bleed screw.
- [SIZE=-1]‒ [/SIZE]Repeat bleeding procedure in stated sequence at other brake calipers.
- - Making allowance for pad wear, fill brake fluid reservoir as far as max. mark and screw on cap.
- [SIZE=-1]‒ [/SIZE]Start engine and check both brake pedal travel and pressure.
- [SIZE=-1]‒ [/SIZE]In the event of excessive pedal travel, check brake system for leaks/repeat bleeding procedure.
On completion of bleeding, perform test drive involving at least one ABS control operation at all four wheels."
Do you know if you have the ABS/ESP ITT Mark 20 or ITT ABS/ESP Mark 60 system? There appear to be slightly different procedures depending on which one you've got.
So, if your reservoir has run empty, you'll need to do all of the above, and will need VAG-COM or similar. If not, then just the bleeding sequence should do it.
I can send you the PDF's of the process if you want to drop me an email address?
