Facelift Audi A3 8V Side Skirt - Rocker Panel Bended / Dent
ivelliosy
Basildon
Hi there. I drove the car over a big stone and unfortunately driver side rocker panel has been damaged :( It seems there is no visible paint damage to the part. Is it repairable via PDR? I suppose there is no way to access to the innerside of rocker panel, maybe some glue pulling would work? I am curious about your comments. It looks like it doesn't affect the door's function as well due to upper side of metal is not bended.
In addition, there is also a damage on underfloor shield near to left side. Are there any critical part under it? I am not sure If I have to replace undershield for this damage. Would it be repairable, not quite sure.
Cheers.
I did a similar thing to my car and damaged the sill. Cost about £3,500 to fix.
Reactions: ivelliosy
Whole sill and some paintwork on rear door. I think it was quite extensive to get the sill off.
Also it was a premium repairer (insurance of course)
Hmm can it be retrofitted as oem? Are there any part numbers? Btw, i still have a hope to repair it with pdr.
Yesterday I went to a premium PDR shop, they said glue pulling is possible but with a risk of coating peel off :( I decided to leave as it is due that It is not very eye catching. A guy at shop told me to fix underfloor plastic with some welding as well. Fyi all.
yea, repair guy told me the same thing.. that's the reason they can't apply glue pulling without peeling off the coat on rockers. they suggested to leave as it is If I don't want a painting job. S3 skirts are expensive as well when I compare with PDR or not touching it at all :)
btw, do you know if there is any important component under plastic shield which I damaged? They told me that they can repair the plastic shield with some heating/welding. Should I go for it or replace the whole shield?
