S3 8V VCDS Scan (FAULT CODE HELP)
Glasgow
Hi I am wondering if anyone can explain the fault that my car has
Saturday,07,September,2019,14:16:34:51585
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8V4EA172399 License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 22 42 44 52 55 5F A9 BB BC
VIN: WAUZZZ8V4EA172399 Mileage: 100415km-62394miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: Malfunction 0010
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 HW: 06K 907 425 A
Component: 2.0l R4 TFSI H09 0006
Revision: --H09---
Coding: 0A1900322426010B2000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0218V0906259 001008
ROD: EV_ECM20TFS021_AU37.rod
VCID: 7DA7FA87ED7DF6FFA1F-8028
3 Faults Found:
17178 - Databus
U1123 00 [040] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 99800 km
Date: 2019.09.01
Time: 12:36:43
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 70 °C
Intake air temperature: 41 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.382 V
Unlearning counter according OBD: 14
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
16799 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99800 km
Date: 2019.09.01
Time: 12:36:43
Voltage terminal 30: 12.460 V
Engine: operating status: ES
ECU_STATE: ENG_STOP
TOIL: 69 °C
Time since engine start: 0.0 s
T_ES: 50 min
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: operated
Cruise control switch actuation-Large increment: not activated
Cruise control switch actuation-Control component verified: No
STATE_ERR_ABC_PRED: 0
15343 - Boost Pressure Regulation
P0299 00 [096] - Control Range Not Reached
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99811 km
Date: 2019.09.01
Time: 15:13:25
Engine speed: 6781.75 /min
Normed load value: 82.0 %
Vehicle speed: 137 km/h
Coolant temperature: 109 °C
Intake air temperature: 57 °C
Voltage terminal 30: 13.554 V
Engine: operating status: PL
STATE_BPA[0]: OPM
Charge air pressure control valve position: target value-POSN_SP_BPA[0]: 26.56 %
Charge air pressure control valve position: actual value-POSN_BPA[0]: 26.367 %
MAP_MES_SAE: 230 kPa
Charge air pressure control valve activation pulse duty factor-PWM_BPA[0]: -32.104 %
Charge air pressure control valve voltage: position closed-VP_BPA_AD_BOL[0]: 3.5547 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 60804000000662
Coding: 32F193A254272A6E017A070941CC694CC92A5480E08296F6024100080608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 7BA3F49FF369F8CF9FB-802E
2 Faults Found:
32865 - Databus
U1123 00 [008] - Received Error Message
[IPB_BUS: Motor_12 / MO_Drehzahl_01]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 99800 km
Date: 2019.09.01
Time: 12:34:57
32867 - Databus
[IPB-BUS: Motor_11 / MO_Mom_ist_Summe invalid]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 99800 km
Date: 2019.09.01
Time: 12:34:57
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000275151
Coding: 03100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 33331CBF9BB9F08F07B-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 9908CD17000000000001
1 Fault Found:
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 96
Mileage: 99800 km
Date: 2019.09.01
Time: 12:36:43
Outside air temperature: 18.5 °C
Compressor current: actual value: 0.000 A
Temperature after evaporator: 23.6 °C
Refrigerant pressure: 1.0 bar
System run time-Engine running time: 0 s
System run time-Terminal 15 on: 253 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011407701071
Coding: 07040A46C24122F503844004B31C07A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140311 041 0580
Serial number: 140317184618
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22405687
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
Component: E1 - LDS MQB H05 0032
Serial number: 10 12 2013 00000851
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140513WHH
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000029248404
2 Faults Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 96
Date: 2000.00.00
Time: 00:00:00
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 136
Mileage: 100092 km
Date: 2019.09.03
Time: 13:20:19
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831408702154
Coding: 0000040001
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_002_VW37.rod
VCID: 38292B9382DF13D7329-806C
1 Fault Found:
13637426 - Databus
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 110
Mileage: 99800 km
Date: 2019.09.01
Time: 12:36:43
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R05WFXA
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4BC3645FE349884F6FB-801E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 001 903 14
Component: SideSensor_Df 001 0887
Serial number: 35767000000B33C06F0Z
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 903 14
Component: SideSensor_Pf 001 0887
Serial number: 35867000000C23C06F0-
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 903 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502C1142B1B4A182
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 803 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502C3142B1B370E6
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 400 702 14
Component: FrontSensor_D 001 6149
Serial number: 3556502AD107DB45731F
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 003 14
Component: PedP_Sensor_D 001 6149
Serial number: 22865029F14D3E7480FW
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 003 14
Component: PedP_Sensor_P 001 6149
Serial number: 22965029F14D3E72518M
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 103 14
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C9142B1C121B%
Coding: 2D2D2D
No fault code found.
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 25031408490866
Coding: A408
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_010_AU37.rod
VCID: 094F9E57A9B5DA5F9D7-805C
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 970 R HW: 8V0 920 970 R
Component: KOMBI H03 2220
Coding: 23AD08022A8046000101EA00100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001755492
Coding: 030100042B085A005B000268080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FDB408FA7F124EFF33-806A
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 08 03 2014 D0418960
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 2846212803
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00019.02.14
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 46D5556BF82B7527B05-8012
1 Fault Found:
16670 - All-Wheel Drive
C1113 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 110
Mileage: 99801 km
Date: 2019.09.01
Time: 13:05:01
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 16031406070151
Coding: 00518E204001040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 40D94373DA0F5B178A9-8014
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 353722A795CDEEBF29F-8060
1 Fault Found:
19460 - Databus
[ESP_05 Botschaft - SNA-Check]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 59
Reset counter: 110
Mileage: 99800 km
Date: 2019.09.01
Time: 12:36:43
Motor status: 00
System status: Waiting for start request
Supply voltage: 12.25 V
Temperature: 34.0 °C
KFC: 4C
KFA: 00 04
Environmental conditions: 21
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 12.20 V
uAdSensI_SwitchedKl30_xdu16: 12.21 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 23031402090344
Coding: 005186204001040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 01AE000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75B7E2A7D54DAEBFE9F-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
Component: MU-S-ND-ER 040 0420
Serial number: A7F02603141094
Coding: 017303010000000021111102000A00002F0005660100010006
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3B23349FB3E938CFDFB-806E
Data medium:
Subsystem 1 - Part No SW: 8V0 919 866 B HW: -----------
Component: ECE 2014 --- 0036
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY301UPZ
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000004021400030400
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140301200388
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
Component: TSG HFS 020 0025
Serial number: 19031403111864
Coding: 004186204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 42DD497BD40349079CD-8016
1 Fault Found:
65588 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 110
Mileage: 100026 km
Date: 2019.09.01
Time: 20:04:10
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0025
Serial number: 19031406070785
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 01:34, VBatt start/end: 12.8V/12.8V)-----------
