Leighspain1975
Hi Guys
Had a look at vcds temps and after a 30 min drive I saw the following :
Temp at radiator outlet specified : 90 degrees
Temp at radiator outlet actual : 36 degrees
I’ve changed the sensors but it reads the same also engine doesn’t seem to get up to temp and when it does it will fluctuate between 89 - 80 degrees.
Is it the thermostat ?.
