Ok, so coil light came up on my vehicle with DPF light with car going into limp mode.
Fault code read: P0234 & P2563
I have tried the following:
Boost at idle is reading 1 Bar in pressure and going over the Max overboost pressure to 3 Bar when revved stationary.
Can anyone advise of what to look at doing/replacing next to overcome this issue?
Thanks.
- New N75 installed. No change
- New actuator. No Change
- New Turbo & DPF 5 Stage clean. No Change
- Wiring loom tested. No fault found
- ECU VAG software update completed. No Change
- New ECU. No Change
- New MAP sensor. No Change
Thanks.
