Hi guys,
Recently I’ve been having an issue with my Audi A3 2010 1.6 TDI. Sometimes I could be driving along, and the car will just shut down and the coil light would begin flashing. I can restart the car and the problem would go away but can reoccur after a few mins, miles or sometimes even days.
I’ve had a brief look with a friends VCDS and it seems like I have an intermittent P2147 error code. Any idea what the likely culprits could be?
Thanks in advance.
Thanks in advance.
Code:
7078 - Supply Voltage for Fuel Injector Group A
P2147 00 [232] - Short to Ground
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 16
Mileage: 143029 km
Date: 2019.10.26
Time: 00:24:21
Engine speed: 2018.25 /min
Normed load value: 23.1 %
Vehicle speed: 34 km/h
Coolant temperature: 34 °C
Intake air temperature: 12 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.214 V
Unlearning counter according OBD: 40
Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 2
Injection valve 1: voltage-V_INJ_MAIN[0]: 121.31 V
Injection valve 2: voltage-V_INJ_MAIN[1]: 126.88 V
Supply voltage of analog output 1-VCC_1: 5.02 V
Supply voltage of analog output 2-VCC_2: 5.02 V
Injection valve 3: voltage-V_INJ_MAIN[2]: 126.62 V
Injection valve 4: voltage-V_INJ_MAIN[3]: 131.72 V
