flashing oil light red
djslm
car is a 1999 s3 apy the red oil light comes on and bleeps three time when engine it at temperature then turns off then on and off there is plenty of oil in it and the engine and turbo works fine i have pluged in the snap on diagnostic but no fault codes it only flashes when on full load and at temperature not when cold thanks for the help in advance
You potentially have a bad oil level/ pressure sensor? Have you noticed any change in the operating temperature or idling which could potentially point to a bad oil pressure pump?
Could be a oil pressure issue I'd remove the sump asap to check the pick up pipe
Yep, I’d bet the pump is on its way out if it’s never been replaced. Worth checking pick up pipe too, as others have already suggested. Have you just had a fresh oil change done? That can highlight a tired oil pump too.
just dropped the sump put in new oil pick up pipe fresh oil from tps and filter now oil light comes on as you move off from cold got no codes from the diagnostic machine the old pick up pipe was clean no clogging up of gunk dont no what to do now the engine sounds sweet and boosts fine
838
14
873
