Hello,
I've been getting y P0441 error - Evaporative Emission System Incorrect Purge Flow
It causes a Engine Management Light to come on. If I reset it it usually goes away for a week or two but has started coming back.
Today I was driving and noticed the car felt lifeless , almost like there was not much turbo - felt like a limp mode but no engine management light on...
I check with Vagcom and see I have pending codes;
P0441 again but this time , and for the first time ever; P0172 - system too rich bank 1.
When I reset it car returns to normal performance
But obviously something is wrong and I should fix it any idea what? Someone suggested the fuel cap could be the issue as the seal is weak. This is a 2012 car and yes the oil cap seal doesn't look perfect but i'd be suprised if it's leaking as it doesn't look cracked either!
Someone suggested replacing the EVAP canister purge valve, is this likely to cause the P0172 issue, or is that going to be my MAF or O2 sensor?
Please help so I don't have to waste too much time or money - it's Christmas!
