- Joined
- Sep 14, 2008
- Messages
- 24,836
- Reaction score
- 6,077
- Points
- 113
- Location
- Wibbleton
- Website
- www.tuffty.co.uk
Sensors > afr... Should be at least...
only bother with lambda...Thanks both, just need to learn how to read the Lambda sensor then I guess.
If you have mapped the cruise buttons to map switching then no, cruise won't work...Hi all, first time posting on here as usually use the facebook group.
Just a question about using multiple presets as this isn't something I have looked at yet, If using the cruise buttons to switch maps does this mean that you cannot now use the cruise control as Audi intended? I use cruise a lot so wouldn't want to loose it.
Thanks a million Badger5, My ECU arrived today, hopefully 610 injectors tomorrow.
Will have a play with the ECU on current Bam engine which has intake filter, and 80mm tip from Badger5, FMIC and 3" down pipe
Plan to learn before I fit new BAM forged motor and hopefully not bend any rods in current motor.
Slow and steady is what I am telling myself but my brain is telling me otherwise.
Is there a more in depth forum for beginners with this iECU.
When did you order website has said no stock for a while now ?Thanks a million Badger5, My ECU arrived today, hopefully 610 injectors tomorrow.
Just need a std S3 or other 20v wideband sensor...Need a wideband sensor, Ignitron mentioned a LSU, can anyone recommend one, I could not find them on the Badger site, Thanks
