Help Please 19" A4 Rotor Wheels
_GRP_
Q3 S-Line
Hi Guys.
Don't suppose anyone here has or knows anyone with some Genuine 19" A4 Rotor Wheels for sale?
Not sure if you know, but there are a number of types of rotors, colours, fit, depth of the centre. I prefer the ones from a5 / a7. The A4 ones are flatter.
Sent from my SM-N960F using Tapatalk
Funny you say as found a set 19x8.5ET43 with tyres in Edinburgh but have to be collected personally as won't allow courier £600 - I'm 500 miles away so might get these RS6 Style instead or 19" segments
Upload 2020 1 9 16 11 29
I've got a Q3 with 18inch wheels, but they also produced 19's in the spec below (but not rotors)
19inch - 8,5JX19H2 ET36
So the closest match to the spec I need (from what I can see) are A4 B8 wheels with the spec below.
A4 19' = 8,5JX19H2 ET43
So combined with 7mm spacers should give me the same offset/spec as above from what I can see?
nice wheels, and thanks for getting in contact.. but these are what I'm after.
 86
Spacers push the wheel out by lowering the ET, so If you had ET43 and fitted 7mm it would change to ET36 pushing out 7mm further.
Think spacers are 3,5,8,10,12,15,20
Exactly, which would then match this spec of factory 19's fitted to the Q3s
https://www.mamfelgen.eu/en/ would you class these as reps? They’re not unbranded and are made in Germany as well as being TUV approved.
There an aftermarket wheel and TUV approved like you’ve said which is a good thing. The reps I was meaning was the copies of OEM wheels which aren’t put through the tests like original manufacturer and good quality aftermarket wheels are like OZ, BBS etc
My apologies, I misunderstood what you had initially said. I take it you mean the likes of the unbranded ones on eBay etc?
Reactions: DickoB8
Yeah there the ones. You will find a lot of OEM wheels are made by BBS and Ronal especially on the German side of things anyway.
Reactions: Radford212
3K
4K
41
11K
