Q3 Armrest issue
drummerdimitri
Is there an easy fix for this issue? That plastic part is supposed to stay attached to the armrest but it keeps sliding out of place.
Surely some hot snot would be a cheap way to fix this but I'd like a better solution as surely the stealership will be asking for a lot of $ for such a simple repair!
You can see these locking pieces in between the 2 bars, just either bend a little upwards or heat & bend up & they should clip into place & stay unless it's stuck at the rear of that piece, hence coming of.
Reactions: drummerdimitri
They bend quite easily but will not stay bent so maybe some hair dryer action is required for a more permanent placement.
Dab them with some superglue, not much just enough to make contact, then push together.
